| Class D Switching Power Amplifiers and Power D/A conversion |
#11 | |
#12 | |
We also use 3 level modulation scheme in our subwoofer amp, in which switching frequency is in phase but audio signal is out of phase, in this configuration the size of output filter could be made small as compared to 2-level. And the damping factor also improves alot . it also minimises the distortion effects and eliminates bus pumping as well.
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#13 |
Are you not concerend with the audio signal being out of phase as in the canceling effect with other speakers which are in phase.
Also there is a difference in the way we hear sounds wether the first peak is positive or negative air pressure, there have been test which prove there is a difference that is why it is very important to insure that the amplifier is in phase or out of phase by 360 deg. |
#14 |
What i was refering to an is a bridged amp comprises of 2 half bridge Class-D amps in which the switching frequency is in phase , but the audio signal is out of phase.
Hope you understand it.
#15 |
The AD1990 - 1996 look nice enought to me. Unfortunately, they are not even in the samping stage yet.
| How about a round-up of Class A kit power amps, or collectable vintage class A? | Brisso57 | Solid State | 4 | 14th February 2007 10:30 AM |
| CCS for PP Class A output stage? | AudioGeek | Tubes / Valves | 5 | 24th January 2004 02:58 PM |
| Class A with AB Output-stage | ManUtd | Solid State | 14 | 1st December 2003 05:49 PM |
| Hart/ Linsley Hood Phono Stage, Power Supply, Class A headphone amp | vaughst | Swap Meet | 0 | 8th February 2002 10:11 PM |
