New version of T-Amp by Rick Bracke New version of T-Amp by Rick Bracke - Page 4 - diyAudio
Old 4th May 2005, 03:27 AM   #31
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Originally posted by motherone
What I truely don't understand is why he doesn't just design a PCB or team up with someone like 41hz.com and just get the things built from scratch as a nice board. He could take it from a hobbyist thing to something truely professional. Oh well, I'm sure with time he, or someone else, will probably do it. Obviously, if he doesn't do it soon, folks like SI who actually manufacture the things will take that market away from him fairly quickly.
I guess the Tripath/Sonic Impact is the new gainclone
Precisely. I think the 41Hz AMP3 kits will take off once everyone gets over soldering surface mount components! I too think the SI PCB can be improved, maybe SI will change the layout in a future realease. Until then, I ordered two AMP3 kits to work on after somehow frying one of my SI's (can't biamp with only one amp). If the sonics are as good I'll be more than happy with the results.
Old 4th May 2005, 07:03 AM   #32
motherone is offline motherone  United States
Sounds like fun.. Please post your results when you finish up.. I've decided to go back and actually finish my 20-some-odd gainclone variants before diving into surface mount fun.. But I do have another SI to finish up at some point!
Old 4th May 2005, 03:58 PM   #33
mourip is offline mourip  United States
My guess is that we are just seeing the birth of this thing...
I looked at the 41mz site a couple of months ago and then emailed them. I suggested that a kit with a lot of SMD soldering would not go too far. I thought that what we needed was a nice DIY board with heavy tracings, all of the signal path parts as through-hole type, and with the chip and SMD parts presoldered. Next someone should follow with a really well engineered amp for the non-DIYers: a "ground up" engineered board with battery management and the ability to keep the board always powered on. My modded SI takes 20 minutes to get frisky and 30 minutes to bloom. It is actually very much like a tube amp in the way it blooms. I am looking into adding a wall-wart 12v supply and a different switching scheme so that my board will be on even while the SLA charges.
My two cents... discounted for inflation.
Paul
Old 6th May 2005, 12:58 AM   #34
JonPike is offline JonPike  United States
Ahhh.. dont let a little SMT scare you. You might need some extra tools, a good magnifier or even a used microscope, and practice longer, but you can do most anything at home.
Old 6th May 2005, 10:48 PM   #35
TNT is offline TNT  Sweden
I'm struggeling with an AMP3 rigth now - **** those smd components are small :-)
I think I have got the hang of it - it's tricky but not impossible if patient.
New version of T-Amp by Rick BrackeHide this!Advertise here!
Rick Wright 1943 -2008 RIP poynton Music 2 17th September 2008 09:41 AM
What is the version of 45 cd149dc Tubes / Valves 3 19th June 2007 11:59 AM
Zen Version 4 skidave Pass Labs 1 19th December 2006 06:36 AM
JLH (my version) bogdan_borko Solid State 4 25th November 2006 08:58 AM
Copyright ©1999-2017 diyAudio
