SMD Capacitor ICE-power - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 15th April 2005, 07:01 PM   #1
El_d is offline El_d  Sweden
Default SMD Capacitor ICE-power
I'm looking for an SMD capacitor that is broken on an ICE-power module.
Please tell me what brand it is and where I can get it.
Old 15th April 2005, 07:17 PM   #2
Pabo is offline Pabo  Sweden
Hi!
Which capacitor is it? I need a picture on the broekn cap and which module it is.
/ Patrik
If something that measures good doesn´t sound good, measure again!
Old 15th April 2005, 08:10 PM   #3
I'm a newbie on this.. Where did my picture go?
Old 15th April 2005, 09:25 PM   #4
It's ICE 500a
Old 16th April 2005, 12:32 AM   #5
sek is offline sek  Germany
sek's Avatar
Default Re: SMD Capacitor ICE-power
Hi El_d,
It's a standard (ie. non-special) electrolytic capacitor.
It's value can be read as 22microFarad (of capacitance), 35Volts (max. voltage).
I don't know about local shops/suppliers in your area, but as it is a fairly standard type, every reasonable electronics guys should be able to sell you one (i.e. an expensive one would be Elfa).
Another good question would be why it failed!
Looks like you accidentally ripped it off...
Sebastian.
Old 16th April 2005, 06:44 PM   #6
Thanks a lot sek.
So you think I should use a standard cap, and not a low impedance cap..?
About the question why it failed...
I think it must have happened during the shipping, It was like this when I received it.
/Daniel
Old 16th April 2005, 08:14 PM   #7
Electrons are yellow and more is better!
peranders's Avatar
Those ICE modules are pretty heavy due to the aluminium and SMD parts are fragile. A normal private person will probably underestimate what the modules will be put through during shipping. => careful packaging and much of chock absorbing stuff.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 17th April 2005, 03:50 AM   #8
sek's Avatar
Hi Daniel,
The one that broke off is a standard type, so no low ESR type is required.
I don't know what it's supposed to do in the circuit (I don't know the schematic), so I can't say what a low ESR type would do here.
Sebastian.
Old 17th April 2005, 03:18 PM   #9
Hi sek.
Then I will go for the standard type.
Thanks again.
/Daniel
Old 18th April 2005, 05:50 PM   #10
Banned
It would seem to me that if you purchased it from ICEpower that it would have been packed properly, and that they would most likely remedy it.
It is probably a bypass for the +/- 12 V rails, judging by its location.
Jocko
Power supply Capacitor, bad design? gain wire Solid State 6 8th December 2008 05:36 PM
When do you need a big capacitor on your power? groover1234 Car Audio 61 2nd November 2007 08:18 AM
Power transformer and Capacitor Drioannis Solid State 6 30th September 2004 04:58 PM
Capacitor across A/C inputs in power supply? Cloth Ears Solid State 8 4th June 2004 02:36 PM
Car Audio Power Supply Capacitor Dustin Haug Swap Meet 0 15th May 2003 03:15 PM
Copyright ©1999-2017 diyAudio
