"grounding" output of T-amp - how?
Old 14th April 2005, 03:18 PM   #1
ThomasS is offline ThomasS  Denmark
Unhappy "grounding" output of T-amp - how?
The main speakers in my system are full range open baffles assisted by an open baffle subwoofer (20-50Hz). The input of the sub-amp is connected via a passive line level x'over (pllxo) to the output of the amp driving the main speakers - i.e. a passive power level x'over :-)
I have just replaced my chip-amp with the Sonic impact T-amp (WITHOUt connecting the pllxo/sub-amp/sub). The output of the T-amp is "floating" (not connected to ground), which means that I can't just connect the pllxo/sub-amp as this will connect one of the outputs of the T-amp directly to ground.. :-(
Is there a simple solution to this "problem"?
I was thinking of creating an arteficial ground by connecting this "arteficial ground" to both output terminal via 2 resistors (e.g. 1-200ohm) - the pllxo would the be connected to positive and "arteficial ground" - will this work? Alternatives?
(I'm working on a buffer which will allow pllxo's to be placed before both the T-amp and sub-amp).
Thank,
Thomas
(sorry for re-posting the question)
Old 14th April 2005, 03:31 PM   #2
subwo1 is offline subwo1  United States
subwo1's Avatar
I remember that I used some 220 ohm resistors somewhere when I was stringing together various pieces in my old multi-amped and equalized set-up. I think they were either connecting the outputs of an automobile stereo receiver or 7 band graphic equalizer/amp into the system. Best Regards.
USMPS
http://groups.yahoo.com/group/switchmode/
"grounding" output of T-amp - how?Hide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
What's the difference between CD Car Headunit and CD Home Player "line output" ? calico88 Solid State 1 1st August 2008 10:54 AM
"active grounding" - why would one use it? jarthel Everything Else 28 20th July 2007 08:51 AM
Wanted: Hammond 125E or other "universal" output transformer Spasticteapot Swap Meet 2 13th July 2007 11:29 PM
do matched pair (or maybe a quad) output tubes "aged" at the same rate? jarthel Tubes / Valves 3 9th June 2007 02:05 AM
