| Class D Switching Power Amplifiers and Power D/A conversion |
Hi Guys,
I'm designing a self oscillating class d amplifier, with feedback from the mosfet. Can you guys suggest a good comparator other than LM311, LM319? and I had search for self oscillating class d amp and found thet most are half bridge. may I know how to use full bridge for self oscillating? (2 output from masfet output stage, output from full bridge is float from ground) regards, Bigbulb |
#2 |
Hi I use LMV7239 by National Semiconductors. It's very fast and best of all, it has a push-pull output configuration.
I know that maxim makes a lot of fast comperators, if that can help. www.maxim-ic.com www.national.com |
#3 |
Thanks sovadk.
I still searching for self osc type of class d in full bridge configuration. I had build the half bridge one and wish to try full bridge. Can't figure out how's the feedback connection, since the speaker output is floating. Please help! |
#4 |
If you understand German a bit, you may want to give this thread a try.
At least the user Beobachter develops a so called (by himself) SODFA as a full bridge version with pre filter feedback. He posted links to the schematics too. Regards, Timo |
#5 |
Thanks Tiki for the link!
#6 |
Account Disabled
You can take it differentially across the load, then use a diff amp to convert to single ended (ugly) or be really slick and keep it fully differential, subtract with differential input, like UCD.
You might want to start with a half bridge though, you'll cook less mosfets getting through the ol learning curve that way. If you go for the fully differential idea you won't even need to change much of anything to go with a full bridge later on. I believe Linear Technologies has some insanely fast comparators and offer some of them with differential outputs as well, might want to have a look at their selection. Cheers |
#7 |
LM319 has two compararors per chip. Now use one chip in double channel UcD (or any other self-osc configuation), one comparator for a channel.
Would the parastic coupleing (via inside or via supply railes) mix two switching frequencies and cause the "whistling" problem? Do I need to use one LM319 chip per channel (and waste half of them)? |
#8 |
Hi Kenshin,
I would not even recommend that you put both amplifiers on the same PCB if you intend to use them for audio. I once used three LT1394 comparators on the same board, and noise level was not Hi-Fi. But for motor control (intended application) it was OK. There was no whistling since this was a clocked design. Best regards, Jaka Racman |
#9 |
put different amplifiers on different board... would it cause more noise from grounding?
#10 |
Account Disabled
Just view them as two lines interconnecting at a star point beyond the amps themselves.
| High Speed Diodes | Fred Dieckmann | Solid State | 201 | 20th July 2011 06:30 AM |
| thorens td 180 in ....high speed | sakis | Analogue Source | 0 | 7th October 2008 08:29 PM |
| high speed CDP | fscarpa58 | Digital Source | 7 | 11th May 2005 08:32 AM |
| High speed amplifier | reinhard | Pass Labs | 13 | 4th June 2002 02:43 PM |
| Page generated in 0.10525 seconds (79.54% PHP - 20.46% MySQL) with 10 queries |
