class d lightning audio (rockford) 1000 watt help - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 1st April 2005, 08:53 AM   #1
zfactor is offline zfactor  United States
Default class d lightning audio (rockford) 1000 watt help
hello all new to your forums. i have here a 1000watt 1ohm class d lightning audio. i have experience with other electronics prior but never worked on class d amps before. i have irfz44n hexfet mosfets burned out (5 of them) customer let the amp get wet!! and a voltage reg that is numbered
K216-
A1266
GR
i can seen to find these or get a good cross on these anywhere any ideas??
also anything else to be concerned with in repairing a class d amp??
the resistors before the mosfets also went with them. those should be easy enough to find though. thanks hope someone can help
Old 5th April 2005, 09:42 PM   #2
FrankH is offline FrankH  Netherlands
FrankH's Avatar
Default Lightning
Hi ZFactor,
5 HEXFETS? Hm Strange. 4 or 8 might be more logical. But that's the easy part. Test and replace if broken.
Is there some sort of (IC Chip)driver, driving the FET's? If there is, that might be broken too.
Than the reg: is it in the control part or the powerpart of the amp?
What are the surrounding values of the (electrolytic)caps connected to the reg?
Try to find out the pin config of the IRFZ and see in what line the broken Resistors are. Tells you a little more about the rest of the circuit.
Better to find some schematics and post them.
Good luck, Frank
Old 5th April 2005, 09:57 PM   #3
IVX is offline IVX  Russian Federation
IVX's Avatar
if A1266 in the to-92 case, then it's 2sa1266 P-BJT 50V/.1A
Best regards,
E1.
Lightning Audio 2000watt Class D confused256 Car Audio 21 5th August 2013 11:32 PM
Help With A 500 Watt subwoofer and a 1000 amp Bgpoet Solid State 2 30th December 2008 08:41 AM
1000 watt Amp Modules Zero Cool Class D 24 29th September 2008 09:32 PM
1000 Watt with usb input ! cph2000 Class D 1 4th October 2007 07:04 AM
lightning audio amp repair doughboi916 Car Audio 14 31st August 2007 10:05 PM
Copyright 1999-2017 diyAudio
