LCAudio Softstart - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 27th March 2005, 12:44 PM   #1
Default LCAudio Softstart
Does anyone have a circuit of the mk2 lcaudio softstart? Seems both mine have stop working. I tried to measure the voltage across the relay and it's 2.5vac on one of them and on the other unit it's 6.5vac. From what I can see the relay coils are 110vac.
I tried to trace/measure the voltage leading to the relay coils. From the input voltage, there is a row of resistors which lead to a SMC which is glass and is red with a green stripe. I am speculating that this is the problem. Is it a diode? I measure the voltage before this component and it's 240vac (australia) and on the other side the voltage bounces around. Is it supposes to oscilate?
Please help
Chris
My UcD400 amplifier
http://members.optusnet.com.au/myamp
Old 29th March 2005, 01:36 AM   #2
I think I've worked out that the problem lies in that diode.
Does anyone know how to work out what type it is? It is red inside the glass (as per normal) and it has a green stripe on the cathode.
My UcD400 amplifier
Old 11th April 2005, 06:03 AM   #3
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
Hi Chris,
Any help with this??
I've seen diodes like that as well but..... I've personally no idea exactly what they are.
I think the best you can do is email LCaudio, they should be able to give you the part #, and maybe a few tips to try too.
Best of luck with it.
Old 11th April 2005, 06:45 AM   #4
Originally posted by classd4sure
Hi Chris,
Thanks for the reply.
I have resolved the problem. It was the diodes. After an extensive googling I worked out they are BAV103. I replaced them and it worked.
I worked out they where under-rated for Australian voltages, so I email the distributer of LCAudio in Australia, they contacted Lars and he confirmed this as well. I have since installed some 600V types now.
I had to use some toothpicks to jam the relays after powerup so I could keep listening during that time
My UcD400 amplifier
Old 11th April 2005, 06:54 AM   #5
Account Disabled
Heh, Right on, nice work, good to hear.
When to use softstart lordvader Power Supplies 27 29th November 2007 11:41 AM
softstart on bpa? Arx Chip Amps 3 17th July 2007 04:40 PM
Softstart for Zv9? sts9fan Pass Labs 7 8th November 2006 02:33 PM
Yet another softstart PCB harryeng Pass Labs 5 24th January 2006 09:25 PM
Copyright 1999-2017 diyAudio
