My fully discrete ClassD - Page 12 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 17th May 2005, 05:29 PM   #111
LBHajdu is offline LBHajdu  United States
This seems to be the only thread where someone has actually built a working module, not just simulated.
How does it sound, for the brief amount of time you can run it?
Do you think it will become a functional DIY project?
Leve
Old 17th May 2005, 05:35 PM   #112
MikeB is offline MikeB  Germany
MikeB's Avatar
Hi !
It does sound quite good, the problem is, the hotter the better...
I think, if solve these "small" problems it will be a functional
DIY-project. I will continue this project later !
Mike
Old 18th May 2005, 03:46 AM   #113
Send a message via MSN to CarlBenton
Default Driver Stages
Sorry if I missed anything. You were talking about driver stages. have you considered using a MOSFET driver for the output stage or are we designing completly with BJT's here? I was working on a Class-D amplifier as my honors project for my BE degree last year where I used a IR2113 and I successfully got 60-80Wrms out and I could actually listen to decent audio.
The problem I got was the ringing on the edges (because they were so fast!) was getting back into my small signal stages. This was the sole factor stopping me getting more power outputs.
I would like to spend more time developing it, but now I'm tied up with my masters project designing a Hi-Fi CD pickup. Check out my site for the basics of the design (CB800D).
http://carlslectronics.webhop.net
Bentech Limited
www.bentech.co.nz
Old 18th May 2005, 04:48 PM   #114
Default Re: Driver Stages
Umm the thread is called "my fully discrete Class D" Presumably it's at least partly a matter of sports.
My own reasons for designing fully discrete circuits are cost, flexibility towards optimisation and (believe it or not)... simplicity. In a half-bridge circuit on a split supply, the extra circuitry needed to interface a comparator living around GND and a FET driver living on the negative rail is about as complicated as and more finicky than both functions executed in 3-legged, 2-junction parts.
Old 20th May 2005, 09:59 AM   #115
Oops, Sorry bruno. My bad! and yes you are right, is is difficult when dealing with the driver chip referenced to the minus rail! One of the problems I was having.
Well, lets keep it discret from now on then. lol
I am interested in seeing this design. Like "bcarso" said, I too would like a schematic.
Bentech Limited
www.bentech.co.nz
Old 20th May 2005, 10:24 AM   #116
MikeB's Avatar
Hi !
I did not post latest schematic because it's not fully functional and i
can't recommend for building... I'll have to redesign the driverstage
completely. I will keep it fully discrete, just for simplicity and to keep
it easy to build.
Mike
Old 24th May 2005, 02:24 AM   #117
Kenshin is offline Kenshin  China
Kenshin's Avatar
The fully discreet input stage is too complicated. Perhaps a LM311 will be better.
Old 26th May 2005, 12:28 AM   #118
sovadk is offline sovadk  Denmark
sovadk's Avatar
It looks to me like you're suffering from a awful lot of shoot throught in your design.
The schematic:
The simulation
The uppler simulation shows the gate drive voltages. The lower simulation shows the output voltage and the current through the output transistors.
The problem is that the n-mos turns on before the p-mos has turned off. This gives a lot of shoot through when the output svings from high to low. You'll probably get a lot of distortion because of this.
The deadtime when the output swings from low to high, is very long. You should try to minimize this.
I've attached the orcad files.
Old 30th May 2005, 12:39 AM   #119
sovadk's Avatar
I've worked on the power stage. This (see the schematic) seams to work well. Theres nearly no shoot through, however the switching time might be too long. You can try to minimize R34, R35 together with R21 to target this.
The basic idea behind this gate driver configration, is to connect the two mosfet gates through capasitors, so that they are always in sync. This also decreeses deadtime.
Shoot through is avioded by taking advantage of the gate threshold voltages. You can't turn one mosfet on before the other one is off.
Notice that the mosfet currents have been multiplyed with a factor of 10 to make them visible.
I've attached the project if any of you would like to work further.
Kaspar Sinding Meyer
Old 30th May 2005, 02:03 PM   #120
Kenshin's Avatar
There's another capacitor coupled toplogy on this forum, use zener to limit gate voltage, use diode to delay.
PLaying with ClassD again TroelsM Class D 12 20th February 2008 08:18 AM
New to ClassD DarkOne Class D 2 24th September 2006 04:11 PM
Discrete fully differential amps and no CMFB rtarbell Solid State 1 24th August 2006 06:22 AM
Fully Discrete Switched PS tguzella^TuX64 Power Supplies 16 27th July 2005 12:29 PM
GC VS classD etalon90 Chip Amps 0 3rd November 2004 05:29 PM
Copyright ©1999-2017 diyAudio
