Go Back   Home > Forums > Amplifiers > Class D
Old 17th March 2005, 12:54 AM   #1
Send a message via AIM to Joep Zonnebloem Send a message via MSN to Joep Zonnebloem Send a message via Yahoo to Joep Zonnebloem
Default Small BIG power for not so high-end class D diys
Hello,
I am a bass player, in the process of building a bass amplifier with class d modules (Zappulse 2.3SE). I have been following some of the class d threads here for some 3 months and I enjoy very much reading the various opinions and ideas of all those different people. I also, in my modest way, learn a lot of them, although I am far from a natural born technician. So far I have constructed a rather untidy (to say the least) kind of test version. I am rather ashamed to show it, considering some of the really beautiful designs of other people in other threads; the picture serves only to indicate in which stage and at what level I am presently. Sadly, it also demonstrates that I need a better camera
The sound of it, however, is beautiful; Lows and mid are deep and warm but fast responding and accurate; the highs and top-highs are crunchy, with only very simple and minimal equalization. It also has a nice, substantial and compact thump in the gut and a pleasant attack.
I feel rather presumptious to start a new topic just like that. My knowledge of electronics is kind of limited; I understand some of the behaviour of some common components in some simple circuits and I am aware of some of the topologies in class D and smps. So go learn, you would say. Well, I decided to accept my limitations and also accept the fact that I dont have enough time (ok, maybe also energy) to go as deep into it myself as would be neccessary to find real solutions. Still, I want to build that nice amplifier and there are a couple of aspects on building with the populare modules (like from Hypex, LCAudio, B&O) that I cannot find specific information on that matches my level and/or purposes. My hope is that other people out there may be in the same line, or at least are willing to contribute with their knowledge on the issue(s) below:
SMPS. (Oh, no, not again. yes, again, hear me out).
As I have understood, switched mode power supplies are much too noisy to be acceptable in a hifi configuration. Hiss, hum or crakle from the speakers can destroy any good music that needs some dynamics, and lets forget about recording altogether. However, I am not primarily interested in extremely low noise-levels. Any bass-stack, whether it be an Ampeg, SWR, Eden or even Aguilar or whatever, will produce some significant hiss and hum when you turn up the volume and listen close. Maybe a few, more or less dedicated, studio amplifiers will be very quiet, but then, in many cases those are not very good in live situations. So I am completely willing to accept some steady noise, as long as it does not follow the dynamics in my playing. One should think that this would loosen some of the restrictions on an smps design. I mean, I sense a tendency that certain specifications are to be matched by default, while I (and I hope more people) would happily give them up, to a certain extend, in return for suffucient power (talking in the range of 1000-2000W) and resistance to the phenomenon of power supply pumping. So that is my aim: A switched mode power supply that is powerfull and suitable for steady bass amplification and that not neccessarily has to be high-end. It would make the difference between a 3 or 4 unit high, 50cm (20) deep, 25 kg (50 pounds) 19 housing containing large toroids and a 2 unit high, 12 deep 15 to 20 pounds housing. This is very important when you have to carry around a 19 rack, possibly also containing a preamp, sound/effectsprocessor, BassPod or the likes.)
There have been some threads dealing with smps for class d: in the thread SMPS design for power amps (Class D in particular) ( SMPS design for power amps (Class D in particular) ), some very creative and skilled technicians (a.o. Bruno Putzeys, analogspiceman, .) have been discussing SMPS design on a high theoretical level. The real content of their postings was way byond my comprehension, but very interesting at the same time. The thread died at the end of november 2004.
In the thread about Icpower modules for PA applications, the issue emerges as well on a somewhat more human level. It seems a very complicated matter, e.g.: because of the limit that the smps design seems to impose on the capacitance of the output caps, the supply is in danger in case power supply pumping occurs. There are some smpss available, though, as many who have been around here may already know. One is the A and T labs smps ( http://www.a-and-t-labs.com/K6_Sw_Amp/index.htm ) of 1000W, designed to power some 2 x 300W or so class A/B amplifier. However, its design stems from 1995 and one may assume that new insights on the issue have evolved since then. Furthermore, it has small output caps and it seems to control only the output voltage rate and not the symmetry, which would make it defenseless against a pumping class D module. (thanks for the explanation, Ghemink, I hope I have understood it well). Other smpss for poweramplifiers are available at http://www.cadaudio.com . They are designed to work well with their own cadaudio modules and with the Icpower ones, which are fullbridged and do not suffer from power supply pumping. Sadly, mainly for this reason they also are not sold seperately.
There MUST be some design possible that would match my (and, again, hopefully others) requirements. This is illustrated, for example, by the fact that Hevos, a Dutch manufacturer of high quality bassgear, will be introducing a bass top this spring that has a tubedriven preamp and a (or more) UCD module(s) from Hypex (not coincidentally the company that Bruno Putzeys works for.), all together in a 2 unit high lightweight 19 housing. I mailed them in the hope to get some information about the setup, but understandably they would not go into details, as they told me in their friendly reply.
So, concluding this too long story: that is what its about. A practical SMPS. I would be happy to see some postings containing info that could help me and possibly others. If not, ok, the thread will sink in the list and dissapear out of sight, big deal. But i think its woth a try. And if, lets try to stick to the topic. I must admit that I myself posted some messages here and there in the past that were more or less off-topic, or not helpful or relevant at all. Im still a little uncertain in my forum-manners (maybe demonstrated by the novel-length of this message..? Sorry)
Besides the SMPS, any ideas on preamping the class D amp would also be highly appreciated. But the main issue will stay smps.
Though its high time to end this introduction, still a few words about myself:
I have been playing bass on (semi-) professional level from the late 70s till the early 90s. I played jazz, fusion, rock, blues and aside from that basically anything that would get me some mony, on fretted/unfretted electric bass and upright bass. Sometimes it was good for a living, sometimes not nearly close. I was a studier, practiced a lot and yet did not reach the level I had in mind. On the contrary, eventually I did not know anymore how to play a normal, functional bassline and in 1990 I decided to try and find a decent job, in which I succeeded. Presently, I am a database consultant (like many flipped musicians, philosophers, sociologists, teachers and the likes) and I like what I am doing. Recently, I started playing again, motivated by a small gig I had been asked for and I noticed how much I missed the feeling and how much a musician I am in my heart. I am also less blocked by ambition and I like searching for good basslines now, played with a good sound.
I am, and have always been, a great admiror of the late Jaco Pastorius.
Electronics: I am pretty comfortable as long as Ohms law and some other basic formulas are applicable in simple equations. Byond that, I tend to get heavily lost. My most creative idea so far was a power supply without transformer, i.e. using rectified and buffered mains AC without any galvanic isolation. In Holland, we use 230V rms, which would render some 320V DC on the rail. The Zappulse in my testamp uses +/- 80V (so, 160V). In some kind of symmetrical setup my supply could power 2 modules. After some rethinking I began to suspect that it would probably mean the surest one way ticked to heaven, where I could serve as a human 320V capacitor for Jacos bass rig
Best regards, Joep
Old 17th March 2005, 02:23 AM   #2
ghemink is offline ghemink  Netherlands
Default Re: Small BIG power for not so high-end class D diys
Originally posted by Joep Zonnebloem
Hello,
I feel rather presumptious to start a new topic just like that. My knowledge of electronics is kind of limited; I understand some of the behaviour of some common components in some simple circuits and I am aware of some of the topologies in class D and smps. So go learn, you would say. Well, I decided to accept my limitations and also accept the fact that I dont have enough time (ok, maybe also energyE to go as deep into it myself as would be neccessary to find real solutions. Still, I want to build that nice amplifier and there are a couple of aspects on building with the populare modules (like from Hypex, LCAudio, B&OE that I cannot find specific information on that matches my level and/or purposes. My hope is that other people out there may be in the same line, or at least are willing to contribute with their knowledge on the issue(s) below:
SMPS. (Oh, no, not againE yes, again, hear me out).
As I have understood, switched mode power supplies are much too noisy to be acceptable in a hifi configuration. Hiss, hum or crakle from the speakers can destroy any good music that needs some dynamics, and lets forget about recording altogether. However, I am not primarily interested in extremely low noise-levels. Any bass-stack, whether it be an Ampeg, SWR, Eden or even Aguilar or whatever, will produce some significant hiss and hum when you turn up the volume and listen close. Maybe a few, more or less dedicated, studio amplifiers will be very quiet, but then, in many cases those are not very good in live situations. So I am completely willing to accept some steady noise, as long as it does not follow the dynamics in my playing. One should think that this would loosen some of the restrictions on an smps design. I mean, I sense a tendency that certain specifications are to be matched by default, while I (and I hope more people) would happily give them up, to a certain extend, in return for suffucient power (talking in the range of 1000-2000W) and resistanceEto the phenomenon of power supply pumping. So that is my aim: A switched mode power supply that is powerfull and suitable for steady bass amplification and that not neccessarily has to be high-end. It would make the difference between a 3 or 4 unit high, 50cm (20E deep, 25 kg (50 pounds) 19Ehousing containing large toroids and a 2 unit high, 12Edeep 15 to 20 pounds housing. This is very important when you have to carry around a 19Erack, possibly also containing a preamp, sound/effectsprocessor, BassPod or the likes.)
There have been some threads dealing with smps for class d: in the thread SMPS design for power amps (Class D in particular)E( SMPS design for power amps (Class D in particular) ), some very creative and skilled technicians (a.o. Bruno Putzeys, analogspiceman, E) have been discussing SMPS design on a high theoretical level. The real content of their postings was way byond my comprehension, but very interesting at the same time. The thread diedEat the end of november 2004.
There MUST be some design possible that would match my (and, again, hopefully others) requirements. This is illustrated, for example, by the fact that Hevos, a Dutch manufacturer of high quality bassgear, will be introducing a bass top this spring that has a tubedriven preamp and a (or more) UCD module(s) from Hypex (not coincidentally the company that Bruno Putzeys works forE), all together in a 2 unit high lightweight 19Ehousing. I mailed them in the hope to get some information about the setup, but understandably they would not go into details, as they told me in their friendly reply.
So, concluding this too long story: that is what its about. A practicalESMPS. I would be happy to see some postings containing info that could help me and possibly others. If not, ok, the thread will sink in the list and dissapear out of sight, big deal. But i think its woth a try. And if, lets try to stick to the topic. I must admit that I myself posted some messages here and there in the past that were more or less off-topic, or not helpful or relevant at all. Im still a little uncertain in my forum-manners (maybe demonstrated by the novel-length of this message..? SorryE
I have been playing bass on (semi-) professional level from the late 70s till the early 90s. I played jazz, fusion, rock, blues and aside from that basically anything that would get me some mony, on fretted/unfretted electric bass and upright bass. Sometimes it was good for a living, sometimes not nearly close. I was a studierE practiced a lot and yet did not reach the level I had in mind. On the contrary, eventually I did not know anymore how to play a normal, functional bassline and in 1990 I decided to try and find a decent job, in which I succeeded. Presently, I am a database consultant (like many flipped musicians, philosophers, sociologists, teachers and the likes) and I like what I am doing. Recently, I started playing again, motivated by a small gig I had been asked for and I noticed how much I missed the feeling and how much a musician I am in my heart. I am also less blocked by ambition and I like searching for good basslines now, played with a good sound.
Electronics: I am pretty comfortable as long as Ohms law and some other basic formulas are applicable in simple equations. Byond that, I tend to get heavily lost. My most creative idea so far was a power supply without transformer, i.e. using rectified and buffered mains AC without any galvanic isolation. In Holland, we use 230V rms, which would render some 320V DC on the rail. The Zappulse in my testamp uses +/- 80V (so, 160V). In some kind of symmetrical setup my supply could power 2 modules. After some rethinking I began to suspect that it would probably mean the surest one way ticked to heaven, where I could serve as a human 320V capacitor for Jacos bass rigE
Best regards, Joep
Hello Joep,
That was a long post, but interesting and quite well summarized. However, never, never try to power your amp directly from the AC mains. You will really electrocute yourself or others. Always use transformers between the mains and the power for the amps. Fortunately, you came to that conclusion yourself, this is really killing.
I think the best way to avoid problems with an SMPS is still to go for a bridged amp. I know, that increases the cost of the project, but you could buy almost two UcD400 modules for that 1 ZAPpulse that you have there. So hardly increased cost and guaranteed no power supply pumping.
I still don`t have my SMPS, it is delayed a bit because of not all components being in stock. After that I still have to build it in the small number of evening hours I have (my day-job takes a lot of my time :-), no I`m not a database consultant, I develop Flash memories)
Anyway, have fun with your project, have fun making music and stay alive and away from the mains without any transformers.
Best regards
Gertjan
Old 17th March 2005, 05:52 AM   #3
Hi Joep,
A power factor corrected switched mode power supply is almost just like a low performance class d amplifier running in reverse. Kind of like a bad sub amp really - it only needs to poorly produce one low frequency (that of the net at a few percent distortion). That, plus it needs to provide galvanic isolation. If a class d amp can do this quietly while handling the music power peaks, a power supply that can do the same should be only a little bit larger and more expensive the class d amp (because it needs nearly an equivalent amount of stuff plus a high frequency isolation transformer).
There simply has not been a large enough market to support the slightly different, but not more difficult design-wise needs of a SMPS for class d amps. The recent flood of high performance, low cost class d amps will soon change this situation, IMO.
What's different about SMPS for class d?
Like the d amps themselves, SMPS's for class d need a high peak to average capability. IMO, they also should have power factor correction with a lot of energy storage (needed to suppress audio line flicker). And they should be designed for very low common mode output noise. This last performance feature would not be especially difficult to do, but it usually not required by the typical SMPS customer so it is not provided.
Regards -- analogspiceman
PS: The unisolated Euro mains can easily be lethal and is much too dangerous for the average DIYer to be fooling around with.
Old 17th March 2005, 06:28 AM   #4
Default Re: Re: Small BIG power for not so high-end class D diys
Whoops, it's one or the other - there's no need for high peak to average capability in the SMPS if there is enough dc link energy storage to supply the audio peaks to the output (i.e. suppress audio line flicker).
Old 17th March 2005, 04:45 PM   #5
Default Re: Re: Re: Small BIG power for not so high-end class D diys
Originally posted by ghemink
Hello Joep,
Best regards
Gertjan
Hi Gertjan,
I already have experienced some interesting phenomena with Mains AC the last few weeks, like 4 resistors expelling very rapidly 4 very neat and identical little feathers of smoke, in a split second, completely synchronously. That was a fascinating sight. On another occasion I found, also in a split second, one pen of my multimeter welded to a copperwire after a very loud pang that made my ears hiss for some time. You can imagine I have gotten a little (lot) more cautious now.. Thanks for the concern, anyway
As for the power supply pumping: how bad will it be? Who has some experience with this? I dont read a lot on it, apart from the theoretical possibility. I have not been able yet to test my amp at its full power. I could try it in my living room, but, depending on the mood my neighbour is in, the effect on my health could eventually be as disastrous as fooling around with AC mains carelessly . So I bought 5 100W lightbulbs with fittings and I am going to connect them in parallel and then the lot in series with a little 8 Ohm speaker (to give me some acoustic feedback) to my output and then try to apply maximum power (in steps, using a regulator) I realize its not a perfect dummyload, but it may serve my purpose, i.e. investigating the tendency to power supply pumping with a +/- 80V supply at full power in 4 Ohms. I will report here on this little test.
Success in assembling the PS! Im very curious for the eventual result.
Best regards, Joep
Hi analogspiceman,
I feel honoured by your posting. As I said earlier, I have been reading your discussions with a.o. Bruno and admire the ease with which you people are able to understand and analyse these complex matters. Its encouraging to read your comment about the expected availability of suitable SMPS in the future.
Do you mean with high peak to average capability that the supply should be able to deliver high peaks, above its normal operational current? And with a lot of energy storage (needed to suppress audio line flicker) that it should have large caps on the output to flatten the switching noise? Then Im starting to get the picture. Sorry for my ignorance, Im still learning
As for the AC mains adventures, see my reply to Ghemink above. In the mean time I have learned to always check and double check whether the apparatus is disconnected from the mains and will always discharge the caps with a lightbulb before touching anything. My proposed powersupply was only mentioned to illustrate my even greater ignorance some time ago
Best regards, Joep
PS, of course I read your correction on the peak to average capability...
Old 17th March 2005, 05:04 PM   #6
Default Re: Re: Re: Re: Small BIG power for not so high-end class D diys
....... So I bought 5 100W lightbulbs with fittings and I am going to connect them in parallel and then the lot in series with a little 8 Ohm speaker (to give me some acoustic feedback) to my output and then try to apply maximum power (in steps, using a regulator) ......
Hm... On second thought I'd better give this concept some more thought.... It may kill my little testspeaker
@Analogspiceman: Are you still developping (theoretically or practically) any SMPS for audio, like you did with Bruno at the time? In that case, do you already have some sort of design that could be tested? I would be very happy to do that! (being VERY carefull on the mains, of course )
Best regards, Joep
Old 17th March 2005, 07:32 PM   #7
Joep,
You think your test-setup is ugly?
Behold my test setup... My girlfriend is lovingly reffering to it as "Het Gedrocht"
Essentially it's a hacked old integrated amp. Just need to put the speaker terminals on the back plate so I can close it up. All electronics in the amp are disconnected, and can be repaired when I move to the real project (budget, budget...)
Yes, the top lid of the icecream box is on the part list...
Old 17th March 2005, 07:34 PM   #8
More...
Old 17th March 2005, 07:35 PM   #9
And finally...
It looks worse on photo than real life... really... I'm serious
Old 17th March 2005, 07:42 PM   #10
Originally posted by Yves Smolders
Joep,
Well, at least it looks like an amplifier and not like a containership
It's pretty crowded in that box...
small a-class power amp non global nfb padamiecki Solid State 4 28th June 2011 10:22 PM
Small Power D class MOSFET Amplifier Needed!! Kazus Class D 8 12th March 2009 02:58 PM
VERY HIGH POWER Class D to run from 12V danielkelley10 Class D 30 25th November 2004 12:57 AM
Copyright 1999-2013 diyAudio
