| Class D Switching Power Amplifiers and Power D/A conversion |
Hi, i am wondering how the turn on/off thump is managed on other modules like UCD or ICE modules. Do they have thump might be the initial question.
If not, how the design permit a direct connection from the LC filter to the speaker? As an example, my IR redisign uses a mute relay because upon turn on, there is a dead time forced to charge the bootstrap cap. I know UCD or ICE module differ a lot, i am just wondering because it looks like there is no relay at all. thanks.
Electronic engineer for automotive market. |
#2 |
Pat,
Indeed in the UcD modules we do not have any relay. We switch ON/OFF the currentsource of the two PNP differential input transistors. Please check the schematic from the UcD what is yet public known. Regards, Jan-Peter |
#3 |
Banned
Is there a link for that schematics? Or you refer only to the UcD patent?
Thanks! |
#4 |
#5 |
Ok, so there is absolute no turn on/off thump?
How is the current source turned on/off, with a constant simple delay, microprocessor controled, manualy?? Is it totaly self contained? Is there some active protection on these UCD modules? thanks.
#6 |
Indeed there is only silence when you switch the UcD amp on.....
(however to be honest, when you put your ear in front of the loudspeaker you will hear a very small "thick") We wait for one second so that the bootstrap capacitor can be fully charged, and the we switch the current source on. We use this ON/OFF part to switch OFF the UcD when there is an overvoltage. In the first version of the UcD180/400 we used a piek current protection hereby was also this mute section used. However we use now a constant current limiter in the UcD modules, this works in a different way and is confidential....... ![]() Regards, Jan-Peter |
#7 |
Thanks.
Sorry to ask, how can the bootstrap cap be charged if Vout=0? In my understanding, it have to be -vcc as long as it needs to be charged?
#8 |
Sorry, confidential.......
But it works Jan-Peter |
#9 |
Ok, i think i get it anyway....while i was playing with the PB12 module, i was "forcing" the bootstrap cap to be charged...it is grounded by the speaker resistance then, so...
thanks very much.
#10 | |
As Jan-Peter said, only a very small thump when you put your ear close to the speakers. I have these modules directly connected to my tweeter, midranges and woofers (active system). Very well on/off switching behavior. No relay needed in between amps and speakers. Gertjan |
| Aleph 2 "thump" | Bakmeel | Pass Labs | 8 | 8th November 2008 09:33 PM |
| How to get rid of "CKK" Sound on "turn off" | riotubes | Parts | 0 | 25th November 2006 03:50 PM |
| help customize "slow turn-on" duration in this circuit (link to schematics inside) | jarthel | Power Supplies | 10 | 17th August 2006 06:05 PM |
| An idea for suppressing the turn-on "bump" | Bricolo | Pass Labs | 11 | 4th May 2003 06:21 PM |
| Is it normal "not" to have any turn on thump? | Duo | Solid State | 23 | 7th September 2002 05:45 PM |
| Page generated in 0.11597 seconds (74.20% PHP - 25.80% MySQL) with 10 queries |
