Another Tripath Opportunity
Old 13th March 2005, 06:17 PM   #1
ohenry is offline ohenry  United States
Default Another Tripath Opportunity
FYI: 41hz.com has started taking orders for their AMP3. It's based on the Tripath TA2021B chip and the kit supplies the board and parts.
The parts look to be of reasonable quality and the board is promised to be better quality than the SI. It has a few more watts than the TA2024 and it'll be interesting to see if the TA2021B has the same magic as the TA2024...
I just discovered it being for sale this morning and thought some others may want to jump in.
Henry
Henry
Old 13th March 2005, 07:08 PM   #2
mourip is offline mourip  United States
They do indeed look promising.
One word of caution. Most or all of the parts are surface mount so you have to be up for that...
I had an email exchange with them and suggested that they might want to also have kits where the signal path parts were not SMD or have a board with presoldered components. Their website has a forum and also an FAQ where they discuss working with SMD parts.
Best,
Paul
Old 14th March 2005, 09:41 PM   #3
Yes, that's the part that gives me anxiety, but I do want to try it. I've had a little good AND bad luck with surface mount components so far. I'll probably try to mount better input caps (Auricaps?) as leads. It seems that good caps will cost about as much as the board.
Henry
Old 14th March 2005, 10:09 PM   #4
We will cheer you on wildly from the sidelines. Let us know how it goes!
The Auricaps might not be too expensive since you can look for lower voltage versions. Also you need to think about what your amp will compare to when you are done. You could be enjoying megabuck sound for under a couple hundred dollars.
Best,
Paul
Old 15th March 2005, 04:49 AM   #5
spots25 is offline spots25  United States
very interesting! I think I'll order one here pretty quick. Should be a fun little project, although I haven't done any 'real' soldering for a few years now, I should be able to handle it
Another Tripath OpportunityHide this!Advertise here!
Heatsink Opportunity PassFan Swap Meet 9 9th March 2010 02:51 PM
FS: Mint pair VOLT BM2500.4--very rare opportunity ludcam Swap Meet 1 17th March 2009 06:51 PM
Help Wanted (Job opportunity) SY Everything Else 7 16th October 2008 02:56 PM
Fast action opportunity. Award winning P-P 845 tube amps for sale rcavictim Swap Meet 1 20th February 2006 03:40 PM
Copyright ©1999-2017 diyAudio
