Possible Quad bridging? - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 9th March 2005, 08:32 PM   #1
Default Possible Quad bridging?
Is it possible at all to bridge the amplifer (already bridged) mentioned in this thread:Class D bridging with this product
What I need is the possiblility of letting one amp handling the positive phase and the other the negative one.
In the same thread there's also a picture regarding quad bridging, this is the function I'm searching for.
Could anyone inside this forum tell me how to this
and hopefully a diy guide, on the basis of the PCB posted on the bottom of the same thread.
Old 12th March 2005, 12:18 AM   #2
any1 ?
Old 12th March 2005, 12:52 AM   #3
Try mailing the question to Jan-Peter at Hypex?
Old 12th March 2005, 10:26 AM   #4
Jan-Peter at Hypex! Is he here on the forum, or can I do a google search for hypex? Either wayI'll try both.
Old 12th March 2005, 10:32 AM   #5
Jan-Peter is on this forum - if you have read the massive UcD180/400 threads you should know him!
Yves
Old 14th March 2005, 03:45 AM   #6
ghemink is offline ghemink  Netherlands
Default Re: Possible Quad bridging?
I checked that picture. It looks possible, however do you want to pursue this? Make sure that both power supplies are completely seperated other wise it will not work. Note that the power supllies of the upper and lower amps are modulated with the input signal. To me this method looks tricky and I would not consider it.
Gertjan
Old 14th March 2005, 06:23 AM   #7
I'd like to pursue it by any means. The scenario is as much power as possible, although it might be unstable. The amps are only to be used for 5 seconds at a time, then switched off again. If they brake, they'll have to be replaced. As some of you probably know now, the amps will be used for SPL competitions.
The picture you checked, was the PCB right?
Gertjan do you have a step by step guide? As all of us know that this procedure is a bit "tricky"
Old 14th March 2005, 09:52 AM   #8
NO, I was referring to the schematic
http://www.diyaudio.com/forums/attac...amp=1110290341
No, I don`t have a step-by-step guide and don`t plan to make one as I don`t plan to do this. I just plan to bridge them in the "normal" way for audio purposes. Competitions where people try to blow the windows out of their cars are not my cup of tea.
Good luck trying this.
Gertjan
Old 14th March 2005, 10:40 AM   #9
Thanks anyways. But we've made sure that the windows won't fall out though.
Old 14th March 2005, 11:22 AM   #10
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Funniest posting of the day, imo.
Not my cup of cheese either, GertJan.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
here we go again - bridging ZV5 ingvar ahlberg Pass Labs 2 13th April 2008 03:16 AM
How About Bridging SE CLS Tubes / Valves 0 15th May 2007 05:22 AM
Bridging virenb Tubes / Valves 3 14th December 2004 12:08 AM
Bridging -new way palesha Solid State 1 26th September 2002 05:30 PM
Help on Bridging NickC Solid State 6 20th April 2002 09:02 PM
Copyright ©1999-2017 diyAudio
