Class D bridging with this product - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 2nd March 2005, 08:21 PM   #1
Default Class D bridging with this product
First post here, so bear with me.
I am looking for a way to bridge two identical (car)audio mono aplifiers 1 ohm stable.
Is it possible to use such a product?
http://www.bmm-electronics.nl/Produc...roduct_ID=3224
I understood that there might be a problem to power the above article, but can't this be done with the dc/dc convert inside of the amp?
Also regarding the common ground for the bridging (if possible?) Can't this just be connected together from each amplifer?
Would be nice if anyone could answer, as ordinary car audio people don't seem to have that much knowledge about it.
If charts over the aplifiers pcb's is needed to answer, I'd be glad to provide them.
Old 2nd March 2005, 09:52 PM   #2
JohnW is online now JohnW  Czech Republic
JohnW's Avatar
If I had to place a bet - I would say that the outputs of your amps. are already bridged - which means you cannot use 2 amps to increase power - unless you have a dual voice coil speaker - one amp per coil.
John
Time is my worst enemy!
Old 3rd March 2005, 02:51 PM   #3
Hi there, the speaker is infact a 2 ohm dual voice coil woofer
Old 3rd March 2005, 03:08 PM   #4
UrSv is offline UrSv  Sweden
UrSv's Avatar
If your amps outputs are completely floating with respect the ground and positive then it might be possible to run them in series on the outputs to obtain twice the output voltage. Check the manual.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 3rd March 2005, 07:11 PM   #5
It doesn't state anything in the manual. But I'd be happy to post the chart over the PCB. I am not really that good at reading it myself.
Old 4th March 2005, 05:17 PM   #6
Anyone got a clue, before I start spending? Or maybe even another way to solve my problem?
Old 6th March 2005, 11:13 AM   #7
Workhorse's Avatar
John
Hi john,
You are right about this amp, but there exist a way by which you can bridge an already bridged amp. but it requires seperate power supplies for the proper operation. Crown and Qsc [pl9.0] uses grounded bridge topology for this type of implementation.
regards,
kanwar
Old 6th March 2005, 05:56 PM   #8
Well, delighted to hear that it's possible with other products.
About the seperate power supply, what needs to be done? Can I use the above mentioned product, or are there any other ways to bridge an already bridged amplifier?
If anyone knows how to compress a pdf into a size that this forum allows, I'd be able to post the pcb chart. Unfortunately its 1,1 mb zipped.
Old 8th March 2005, 12:59 PM   #9
Workhorse's Avatar
Lightbulb Hi buddy
Hi chocolate_jay,
Its not possible with the mentioned product.
See the picture for more clarification on QUAD BRIDGING TOPOLOGY.
Hope you understand it.
regards,
kanwar
Old 8th March 2005, 01:32 PM   #10
For those experienced enough, here's the chart over the PCB.
Sorry for the resolution
This product may contain.... Spiny Everything Else 8 18th July 2009 01:16 AM
Has anyone used this product??? bowdown Solid State 12 18th August 2006 05:59 AM
Bridging class AB amp and keeping full range wakeprodigy Car Audio 2 25th March 2006 03:59 PM
Commercial Product cyclotronguy Solid State 33 9th April 2005 07:03 AM
Any opinions on this product? G Multi-Way 7 29th March 2003 01:21 AM
Copyright 1999-2017 diyAudio
