How eliminate offset voltage in my design
Old 1st March 2005, 06:20 PM   #11
Peter_ma is offline Peter_ma  Taiwan
During testing, I choose that circuit (picture)as feedback
Figure (1) is shown the waveform at (C) when only a diff amp was connected to A and B.(EA ,comarator were disconnected, signals provided function gen.)
After, EA and Comparator were added.
Fig(2) is shown the waveform at negative input of EA.
Fig(3) is shown the negative input at comparatorLM361.
Both fig(2)&(3) were failed to get the proper input to LM361 which need +/- 5V input signal applied.
I replaced R15 with 1.5K but the negative input at LM361 nearly the same as Fig(3). The DC offset was still around -8V. The sin wave always seem disappeared.
I am quite confused.
What is the principle of feedback using diff amp (why need do that way? I build this feedback just by reading information searching from webs and old posts and some hand calculations ¡Kbut I still cannot really understand ¡K )
Also what is the role of EA in this case? What should be possible correct signal at negative input of EA?
More important¡K
Subwo1 mentioned that ¡§The best way I know to eliminate the chance of it is feedback referenced to a fixed point between power supply rails.¡¨
In both fig(2)(3), there always a dc offset. I am afraid ..How the feedback cirucit can eliminate the dc offset?
How can I change the circuit(feedback, ..,even power stage)?
Thanks...all experts
Old 1st March 2005, 06:20 PM   #12
waveform (fig1,2,3)
Old 1st March 2005, 11:02 PM   #13
bjorge is offline bjorge  Norway
You should measure the offset between A and B. As already mentioned, with a single rail you will of course have a DC offset. Ideally it should be 6V with 12V rails, but you haven't added a "virtual" ground that would serve as a reference point.
It could be achieved by biasing the +input of U9B to +6V and feeding the input signal via a capacitor, maybe.
Regards, Bjørge
How eliminate offset voltage in my designHide this!Advertise here!
Acceptable DC offset voltage hags Chip Amps 2 8th March 2007 10:56 AM
Offset voltage borges Multi-Way 3 17th May 2006 07:38 AM
Offset Voltage Indicator? Stocker Solid State 39 22nd April 2004 04:23 PM
DC Offset voltage phil Solid State 3 23rd October 2001 06:37 AM
DC offset voltage? harbin Solid State 2 13th June 2001 06:51 PM
Copyright ©1999-2017 diyAudio
