plitron part number for UCD400
Old 15th February 2005, 07:56 AM   #1
onixuser is offline onixuser  United States
Default plitron part number for UCD400
NEWBIE alert!!!
i just ordered 2 ucd400 modules from adireaudio to start building my first DIY audio project
can somebody point me to the right plitron transformer part# to use.
this is my current plan:
use a single 1000VA transformer and 2 sets of bridge rectifier for the +/- lines
and while you're at it can you please point me to the right rectifier diode and filter caps to use for this project, i'm not very familiar of the type/brand/part# of parts that are available.
i'll decide on the capacitor values to use once i get their prices
thanks a lot in advance,
angelo
Old 15th February 2005, 09:14 AM   #2
Duck-Twacy is offline Duck-Twacy  Netherlands
Noob advice to newbie.
I would go for the one with 40 V AC secondary (in de standard range).
The 45 V AC is just on the edge of the allowable DC voltage. If you want a little more power, go for a 42V AC, but I don't see those at Plitron.
Correct me if I'm wrong.
Is that all there is?
Old 16th February 2005, 07:33 AM   #3
thanks for the reply,
i keep on reading good things about the Rubicon BG caps,
10,000uF 63V (solder lug) $140.20
10,000uF 80V (screw leads) $168.68
these caps are expensive... is there another brand that's comparable to the BG if not better and cost a little less...
shld i go with the 80V, or the 63V should be enough for the UcD400 w/ 4 ohms speaker?
angelo
Old 16th February 2005, 08:24 AM   #4
rha61 is offline rha61  France
you can use softrecovery diodes : MUR860 , RURP860 ...
alain
plitron part number for UCD400Hide this!Advertise here!
Fet dravers part number? Bad silver Car Audio 2 22nd June 2009 06:52 PM
Jfet part number mmerig Parts 5 23rd September 2007 05:19 PM
Need part number for a transformer bluegti Chip Amps 16 27th December 2006 04:06 AM
motorola transistor part number contaxchen Solid State 6 25th February 2005 03:46 AM
Copyright ©1999-2017 diyAudio
