Nth order noise shaping
Old 19th February 2005, 12:43 PM   #21
sovadk is offline sovadk  Denmark
sovadk's Avatar
I see. How do you explain the difference in SNR?
Old 21st February 2005, 06:55 AM   #22
phase_accurate is offline phase_accurate
There are several reasons IMO:
1.) Nothing ever works as good in practice as it should work in theory. If it really would, then the Sharp D-S amps would have a much better SNR than their 100dB (Theoretically 270 dB @ 20 kHz).
2.) The chosen dither is certainly not optimal.
3.) The chosen NTF may not be optimal either since I didn't spend too much time on detemining it. I just chose 200 kHz cutoff and fourth-order Butterworth for the NTF and then derived the coefficients for achieving it. This choice is quite critical: the lower the cutoff frequency - the worse the SNR, the higher it is (i.e. aggressive noise-shaping) - the more the loop is prone to instability.
Nth order noise shapingHide this!Advertise here!
Onkyo VLSC Vector Linear Shaping Circuitry rjm Digital Source 4 18th October 2011 11:10 AM
1st order Passive Line Level Crossover + 2nd order Highpass? alexclaber Multi-Way 11 4th January 2008 07:15 PM
deceptive perception ? 1st order-2nd order question poldus Multi-Way 4 10th April 2007 11:58 PM
Magnet proximity and faceplate shaping kyrie48 Multi-Way 12 10th September 2006 09:32 AM
1st order ? L-R 2nd order? or transient perfect?? Ken L Multi-Way 6 17th October 2003 04:22 PM
