| Class D Switching Power Amplifiers and Power D/A conversion |
#501 |
I got a hold of a used Sonic Impact for $20 and about to do some moding. I know that there are lot of moding instruction from this link but it would take me hours of reading to pick up piece and pieces of info. Is there some other link that would provide steps to mod without having to read 50 pages.... Thanks in advance.
#502 |
For the new board:
http://www.diyaudio.com/forums/showt...07#post1210107 For the old one: http://www.michael.mardis.com/sonic/inputmods.htm |
#503 |
You are the man bumblebee - thank you. By the way what does it mean "jumped" from "removed and jumped" in c4. I do know what remove mean but jump??
http://www.diyaudio.com/forums/attac...amp=1179144873 |
#504 | ||
![]() Quote:
As in "bridged by a jumper" or small bit of wire in this instance.
Take the Speaker Voltage Test! |
#505 |
Do I put a piece of wire in place of the c3 and c4 cap or in between c3 and c4. Thanks.
#506 |
This means to solder a piece of wire to bridge(jump) the connections. This provides connectivity to complete the circuit for devices which have been moved off the board. i.e. a piece of wire has been put in place to bridge the missing device.
Davet |
#507 |
Got it now. Thanks much Davet.
#508 |
Its quiet here, too quiet
On my new T-ampīs plug i got the two red wires at the right side and opposite of the photo and illustrations here? Should i just go on and isolate the red wires but not together and use the wires as in the plan, starting with the #1 left one(all the white ones)? Thanks Aron |
#509 |
I am not completely following you. I would suggest that you make your connections based on the photos you would find here or on Panomaniac (Michael Mardis) website.
The position of the wires is more important than the color. It would be much easier for us to help you if you could post a photograph.
Davet |
#510 |
Hi and thanks Davet.
I was thinking the same too and wired the plug starting on the left #1 wire. It is working!! Just confusing since my plug wires was oposite and the 2 red wires is the 2 on the right side. Best Aron |
| Page generated in 0.11497 seconds (74.11% PHP - 25.89% MySQL) with 11 queries |
