Sonic Tripath Investigations
Old 10th February 2005, 08:41 AM   #31
Erukian is offline Erukian  United States
Erukian's Avatar
Send a message via ICQ to Erukian Send a message via AIM to Erukian Send a message via MSN to Erukian Send a message via Yahoo to Erukian
I have a quick question i hope someone can answer.
If i buy the SI t-amp, and i crank the pot all the way up, and use my computer's soundcard to lower the volume to good levels -- use it like a preamp, will the t-amp distort/clip on my 94db/sensitive 8-ohm klipsch's?
E-MU 0404 >> ratshack gold 1/4" RCA adaptor >> ratshack 'fusion' 3' cable >> Teac Tripath amp (unmodded) > monster xp cable > Hsu STF-2 Subwoofer > more speaker wire > Onix Reference 1 speakers.
Old 10th February 2005, 11:37 AM   #32
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
If your soundcard has enuff gain, sure... but it will be pretty loud.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th February 2005, 09:20 PM   #33
Pano is online now Pano  United States
Pano's Avatar
As noted above, it all depends on how loud you go. You will get a good 4.5 watts before clipping, that should be very loud on your klipsch. You'll still only get ~1/8 watt average musical power per channel without clipping. Unless you have a huge room, that will be pretty loud at 94dB/watt.
You may not want to run the SI pot all the way open. Try 1/2 way first and make some tests. Let us know what you find.
FYI, the 10 o'clock position gives unity gain .
Take the Speaker Voltage Test!
Old 11th February 2005, 12:01 AM   #34
Erukian's Avatar
From reading about the SI amp, i've picked up from somewhere that the pot does some bad things to the sound if it's not at 100%. Because i've read that if it's at 100% and if you hook up a good pre-amp then it sounds better. Is that true then?
It's pretty easy for me to add a trim pot to my output stage on my professional soundcard. So add like a -30 db trim and then it should all be righteous. right?
Old 11th February 2005, 08:36 AM   #35
motherone is offline motherone  United States
If you're not afraid to open the SI up and do some soldering, you could just bypass the potentiometer altogether. To do this, you would need to open up your SI, pop out the volume board, and solder the volume in for each channel to the volume out.
To do it right, though, I would just suggest popping the main board off it's support and solder pin 3 to pin 7 and pin 4 to pin 6 on the volume board connector. Then just remount the board, maybe with some hot glue, or remelt the plastic, and you should be good to go.
Volume connector pinout:
(from Left to Right, looking down at the top of the board):
1 2 3 4 5 6 7
1 = switch 12volt out
2 = switch 12volt in
3 = to volume from right channel
4 = to volume from left channel
5 = ground
6 = from volume control to amp left channel
7 = from volume control to amp right channel
Old 15th February 2005, 02:07 PM   #36
Bill F. is offline Bill F.  United States
Bill F.'s Avatar
I'm trying to figure out gain structure to tri-amp with SIs. What's the input signal volage at onset of clipping?
Bill
Old 16th February 2005, 04:57 AM   #37
Pano's Avatar
Good question. I'm not quite sure, but do know that unity gain is at about 10 o'clock on the volume control.
Tripath say optimum gain is 12V/V. I think the SI is lower than that but I can clip it with my portable CD player and it has a low output. I'll check into it.
Old 16th February 2005, 01:37 PM   #38
Gary P is offline Gary P
Gary P's Avatar
The gain of the SI is more like 21.6V/V. For the gain of 12V/V as shown in the Tripath datasheet the gain of the inverting opamp input stage is 1 (20K/20K). In the SI the gain of the input stage is 1.8 (36K/20K).
Gary
Old 16th February 2005, 09:29 PM   #39
Pano's Avatar
Thanks Gary!
Old 16th February 2005, 09:36 PM   #40
Bill F.'s Avatar
Wow, so <0.4V on the input is all I'll ever need? That's quite a bit less than other amps... Good to know.
Thanks guys.
Sonic Tripath InvestigationsHide this!Advertise here!
6c45pi : sonic utopia or sonic hell? Kashmire Tubes / Valves 30 25th November 2012 02:00 PM
help with mod on sonic t-amp thezaman Class D 0 28th September 2007 01:28 PM
bi-amping with sonic impact t amp/using sonic impact amp for headphones jon_m Class D 3 16th February 2006 11:16 AM
Sonic Impact / Tripath $16 each tiroth Swap Meet 10 26th February 2005 06:05 AM
Tripath Amp tab30 Solid State 1 22nd November 2001 02:15 PM
Copyright ©1999-2017 diyAudio
