Help with Class D Amplfier Design (feedback) - Page 11 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 3rd February 2005, 02:37 PM   #101
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
You can also have intermodulation products between different channels that tend to produce annoying "whistles". That's a defect of every self-oscillating Class-D amplifier.
I wouldn't go so far as to say it's a defect, but sure it's a possibility. I understand this same problem exists in poorly implemented clock based designs as well, there's always a work around isn't there? You have to admit, the definite pro's far outweigh the possible cons.
Old 3rd February 2005, 10:26 PM   #102
Send a message via MSN to hypnopete
Does anyone know a good and reasonably simple way to set up some clipping led to a digital amplifier, ie the design i have come up with.....?? is the easiest way to use a comparator for example, when the output voltage reaches 99% of the rail voltage... any other ideas...?
Peter.
Old 3rd February 2005, 10:32 PM   #103
Account Disabled
Originally I'd clamped mine at the input, two pairs of series diodes for about +-1.2 volts limiting. Later removed them I found they weren't needed in my case.
Old 3rd February 2005, 11:26 PM   #104
Perhaps you misunderstand.
All i want to do is give some visual indictation that clipping is occuring..
Peter
Old 3rd February 2005, 11:31 PM   #105
Account Disabled
Yes I did, and that's a good idea.
How about a PLL set to lock on 150Khz
Old 4th February 2005, 01:36 AM   #106
subwo1 is offline subwo1  United States
subwo1's Avatar
For clipping indicators, consider two zeners, one at the upper and one at the lower rail. A resistor connects them together. The LEDS attach to the inner connections of the zeners, observing proper polarity with series 1amp 200PIV rectifiers in series with as well as the necessary current limiting resistor for each LED. The higher the voltage rating of the zeners, the farther from the rail the indicators will sense the audio signal. The LED assemblies are connected to the audio output.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 4th February 2005, 01:59 AM   #107
Okay I'll Give that a go!!.
I think i could probably get away with just using one led, and monitoring on only one of the rails, probably the top.
Thanks.
Old 4th February 2005, 05:22 AM   #108
subwo1's Avatar
Sounds good. The rectifier should be an ultrafast or two 1N4148 in series.
USMPS
Old 4th February 2005, 06:24 AM   #109
Clipping detection within class-d:
If one drives a class-d amp into clipping it stops switching. I.e. one output device is kept on and the other one off. This situation can be detected at the input of the mosfet driver by means of a retriggerable monoflop.
Charles
Old 10th February 2005, 10:03 AM   #110
I have just finished winding my new Torroidal Inductor, which is for use at around 300kHz.
As i was unsure of the core material, mix. ( powdered Iron)
I set up a parallel resonant circuit with the inductor and a 1.0uF capacitor.
The resonant peak was measured at 11.5kHz.
According to my calculations, ie L=1/(((2*pi*f)^2)/C)
The inductance is 191uH!... This is much too high i beleive . There are 42 turns on the inductor.
Should i just use say 10 turns instead of 42? to get something in the ball park of 47uH?
Any help would be much appreciated. I am not sure of the exact value i need either.
Peter
SE J/MOSFET Class A Amp, no Feedback widowmaker Solid State 5 11th July 2013 06:38 PM
how do you design a class d feedback network? Randy Knutson Solid State 3 30th August 2003 06:00 AM
Copyright 1999-2017 diyAudio
