Go Back   Home > Forums > Amplifiers > Class D
Old 12th January 2005, 01:50 AM   #21
Kenshin is offline Kenshin  China
Kenshin's Avatar
And,how about UcD's patent? connecting a NFB from output and make the system self-oscillate, will this touch their patents?
Old 12th January 2005, 06:15 AM   #22
Pabo is offline Pabo  Sweden
Kenshin
I am not sure what you are referring to specifically but the ucd-patent and the ICEpower-patent are different in the way that ICEpower uses a separate 2nd order filter before the output filter to create the phase modulation while ucd uses the existing 2nd order filter itself.
None of these patents claim a zero in the feedback loop.
If something that measures good doesn´t sound good, measure again!
Old 12th January 2005, 06:26 AM   #23
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
Hi Pabo,
It is because of what Charles said I believe:
"...Because the feedback thingie is not restricted to polyphase PWM in B&O's patent it does cover almost any PWM topology where the phase-lead is generated by a lowpass around an inner feedback loop.
It does however not cover any other topology that generates a phase-lead.
Charles
How many other ways can you create a phase lead? UCD uses lead compensation... you're right though I don't think it is one of their claims.
Ooooooooooohhhhhhh look.... tripath owns that patent
http://www.acutechnology.com/ClassD/...05909153__.pdf
You know .... IMHO, there's far too much concern here over who's got what patented, use what works best!
Old 12th January 2005, 06:49 AM   #24
I was aware of that patent but it 1.) mentions the old-fashioned method with the parallel feedback capacicor as prior art (i.e. the patent claims don't cover this) and 2.) the proposed topology is a little complicated IMO. AFAIK they don't use it for their own audio amps. I somehow remember that they wanted to use this principle for RF applications rather than audio but have to think where I got this from.
I just saw that my statement about the feedback around the inner loop was a little unprecise. No one could say anything if you use lowpass-filtered NFB around maybe an OP-AMP for making a phase-lead, even if it is the part of an inner loop of a switching amp. What is claimed is the lowpass-filtered NFB around a modulator stage.
Charles
Old 12th January 2005, 06:54 AM   #25
Kenshin's Avatar
I found the UcD patent WO03090343 at
http://l2.espacenet.com/espacenet/ab...B=EPD&DRDB=EP1
and the feedback do include a zero.
http://l2.espacenet.com/espacenet/bn...+03090343A2+I+
Originally posted by Pabo
Kenshin
Old 12th January 2005, 07:01 AM   #26
Kenshin's Avatar
Rf//Cf...UcD has it,Tripath has it...and SODA has it....
is it still a valid patent?
if somebody use it commercially,what would happen?
nothing? or be charged of BOTH UcD & Tripath?
Old 12th January 2005, 07:26 AM   #27
A diifferentiating feedback branch as such is a well-known feedback control topology. That part alone would not be enforceable IMO.
Charles
Old 12th January 2005, 01:16 PM   #28
Kenshin's Avatar
what about use 180 deg of phase lag to oscillate?
Charles
Old 12th January 2005, 01:23 PM   #29
Then you would definitely have to think about a topology that isn't covered by either UcD or ICE. It may be possible but I don't have any usable idea in this direction at the moment.
Charles
Old 13th January 2005, 04:33 AM   #30
Kenshin's Avatar
Charles
But any feedback from the filtered output implies a possibility of phase shift exceeding 180 deg and oscillate--at a frequency of 500KHz, parastical paramters such as delay of the opamp could cause unexpected oscillation easily.
A namely(topologicly) "hysteresis" or "carrier-driven" D-amp (even a namely class AB amplifier)may well be a "180 deg of phase-shift" one in fact. Boundaries between tham are clear theoreticly, ambiguous in schematic (can you tell me how SODA oscillate at a glance on its schemetic?) and almost impossible to recognize in real-world systems.
This means that "180 deg of phase-shift" modulator is rather a combine of parameters than a topology.
So it's probably that enforcing the "180 deg of phase-shift" patent really means patent the feedback from output filter and enforce it.
Crossover order and phase shift NV&H Multi-Way 1 28th December 2008 08:31 AM
Phase shift smps topology darkfenriz Power Supplies 12 10th August 2008 11:30 AM
Zero phase-shift gareth Solid State 11 9th May 2008 04:45 PM
Signal phase shift through a tube amp d1camero Tubes / Valves 8 13th November 2006 03:18 PM
Zen Phase Shift, Feedback in BOZ Jay Pass Labs 3 17th February 2003 04:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
