JBL PB12 subwoofer, Class D amp, dead. - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 31st December 2004, 11:21 PM   #21
JohnW is offline JohnW  Czech Republic
JohnW's Avatar
Well at least from central Europe - A Happy New Year
Looking at the PCB tracking - it would apear that the MOSFETS are all Nch. If there are no MOSFET drivers - then I wonder how they drive them with the 74AHC14?
Circuit would be interesting...
John
Time is my worst enemy!
Old 1st January 2005, 12:01 AM   #22
pat allen's Avatar
Yes, they are both n channel mosfets. I am reversing the design now and hand write the schematic.
The v- mosfet is drived by one of the two schmit trigger chip, and is referenced to v- , no to ground, while the v+ mosfet is drived by the other chip, referenced to ground then.
Maybe one of the flaw in the design?
Happy new year John !
Electronic engineer for automotive market.
Old 1st January 2005, 12:08 AM   #23
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
Happy new years guys.
Have a look at the supply line for the upper schmitt IC "driver" see if it's powered by a bootstrap cap/diode circuit. One thing I read about as well is caps going bad on these... maybe that's the one? Seems off for that to go but.... hey *shrug*. Sounds like reaaally weak drivers anyway.
I'm also surprised it's only a half bridge, if it is harris, all their patents I've seen seemed to use a full bridge. Maybe you can take the IC's off and test them in a dumby circuit for basic operation or something.
Cheers
Old 1st January 2005, 02:17 AM   #24
pat allen's Avatar
Ok, here is my first drawing, duno if it is 100% acurate. It seems that there is a boostrap to power up the upper 74, with c5 and the diode on its right.
maybe i have done mistake while reversing it, but it seems quite simple.
Any tought???
thanks and a happy new year to every one !!!
Old 1st January 2005, 04:59 AM   #25
pat allen's Avatar
Ok, after some testing on my bredboard, the schmitt trigger chip for the v- mosfet is shot, toasted, dead. All other components test good, even if they look burned (because of the way i have removed the epoxy, with a flame torch ).
Looking at the schematic, there is not protection diode on its vcc line, while the upper one, got one. You should see a zener diode at the right of c5 rather than a plain diode.
The vcc for this is issued from the bridge rectified -95v, with some diodes and 3x 10k resistor in parralel, making a -89v if measured from the ground. This chip (IC2) is referenced to the -95v, so it got +6v at its vcc.
I will build a prototype with better voltage limitations/protections for both chips, with more caps for filtering, there is very few of them, actualy only 0,1uf.
The opamp is also very badly powered. It is by the means of 3x 4.7kohm resistor in parralel, 2w, and a 15 volt zener diode, same circuit for the +vcc and -vcc, making a poors man +15 0 -15. Source is directly from the bridge rectified +95v and -95v There is no decent caps on this too, only a 100nf on the main board of the whole unit. what a sh*t.
Sorry for my poor schematic, i will do a better one with my cad (power logic) when i will go back to work.
Old 1st January 2005, 05:03 AM   #26
Account Disabled
Hi, nicely done I'm impressed!
I think I see the basics on how it's trying to work. Simple for sure.
Few things I'm unsure of.
After the bootstrap circuit, there's a diode, a 5kR, then an inverter, the positive supply of that inverter looks like it's connecting to to all that, is that the case? AAAAhhh, the 5kR must be a collector load. I bet that diode must be a 12V zener.
I'm not seeing anything that would charge that bootstrap cap on power up.. but I see you have a bit of a line/something drawn up above that doesn't seem to go anywhere, are we missing anything from this?
What connects to that... inverter? that goes to the BJT's emiter? Not the feedback point?.... I can't figure that part out at all, but I don't see any other place for a feedback input, John?
IRF640's... switching pigs. You can certainly improve on that choice.
I have a feeling there's an error in those "driver" voltages.
Being N channels you have to bring gate +~12 with respect to source to switch on, it looks like the ground is wired to -95+12, it would always be on and couldn't turn off like that.
All the rest seems like it could make sense to me
Regards and Happy New Year
Old 1st January 2005, 05:27 AM   #27
Account Disabled
You were posting while I was writing.
Nice work you're on the ball! Don't need my 2cents but I cant' stop myself, nothing on TV.
So what do you suppose that inverter off the BJT is for? I can take a few guesses but.... nah, not at this hour.
I knew something was fishy with those voltages. 6V was my first guess but it didn't make sense so I kept looking at it, hard to make out the writing too. I would think that would have burnt the mosfet out before the inverter though, not turning it fully on. If the driver is burnt, the mosfet must be, are you positive it's OK? Burnt mosfet would go along way to explain that loud hum you had too. Wow, how'd they let it go out the door like that? Something to be said for DIY alright.
There needs to be some type of means to charge that bootstrap cap on power up too, with a delay, you already have the zener there, you just need two more resistors, one from positive rail to one side of the zener and one from the other side of the zener to the negative rail (thanks John), maybe you have a delay with it already too? You dont' really need another zener on the lower one, not if say it were comming off a 12V linear regulator IC.. or any "decent" regulated supply of some sort, which it sounds like you'll be adding.
Maybe since you're redoing it you'll consider using a decent gate driver IC, but if that worked with those mosfets, adding decent mosfets for switching should be enough of an improvement to let you sleep at night.
This was fun, thanks!
Old 1st January 2005, 08:42 AM   #28
Account Disabled
funny, yet, not really.
Right out of no where, dawns the light.
That inverter on the bjt+diode... start delay / precharge. Seems you knew that "SD" Start delay.. You know what that's the coolest part of the whole amp!
Anyway, you seriously did an excellent job reversing this thing, and in no time at all.
So, is there no feedback on this thing?
Old 1st January 2005, 03:00 PM   #29
JohnW's Avatar
Hi Pat & Chris,
Well done in tracing the circuit so quickly.
The modulator circuit doesn’t make much sense – where’s the oscillation element? I would have expected to at least see a feedback path from the OPS to the first integrator via the integrator Cap or a resistor… If the Cap was connected from the OPS then it would look a little like UCD / hysteresis switcher…
A Single ended Sub amp – now that’s just asking for trouble! - now I wonder why the PSU caps are so big
John
Old 1st January 2005, 03:06 PM   #30
pat allen's Avatar
Ok, i have tripple cheked the boostrap circuit, i did a litle mistake, the zener is on the right side of the 5k resistor, not directly in parallel with c5.
D6 might be responsible of some sorf of initial start?
The RF connector on the top left corner is connected to nothing on the pcb, but is there.
i am not that much familiar with class D amps, but i see the main thinking behind it all.
What surprises me is the total absence of active protection, wathever is happening, full dc voltage will go thru the woofer.
Yes, i am 100% sure of that, both mosfets are ok.
On the main board, there is a feedback resistor from input to output. 56.2k.
SD is some sort of protection where it stops the unit to oscillate, but isnt there somethin wrong with this, one of the 2 mosfet will stay on then?
On the other schematic i have (original PB12 power amp module version 2), they show a lot more filtration caps for the opamp, and the IR2111 driver, so they knew it was a flaw in the design .
There is a relay and a temperature sensing on the "better" circuit. Maybe i will inspire myself in doing my protoype
Thanks for all the good comments.
Pre-design of my class D amp...PB12 related pat allen Class D 2 14th October 2005 05:17 PM
FS: SVS PB12-ISD/2 SUBWOOFER! **Local Pickup In Florida** chops Swap Meet 3 10th July 2005 05:37 PM
JBL PB12 dead? turkish621 Subwoofers 10 28th May 2005 02:11 AM
Copyright ©1999-2017 diyAudio
