| Class D Switching Power Amplifiers and Power D/A conversion |
#101 |
I didn't mean the same PHYSICAL chip, but the same TYPE of chip... I guess I need to be really specific on this one. Yes, my board revision may be different than yours, but I would imagine they are very much similiar. I haven't checked my hexfet's yet. I might not get to stuffing the board until later this week, not sure yet.
What differences have you noticed between the rev. 6 and rev. 7? Cap C11's marking is 104, as stated in the table I added at the top of the schematic, along with the rest of the components. Jer |
#102 |
That is very cool, as long as we are fixed on the components values, all of us will be able to fix this weak module.
I have also noticed that you have fixed the reference designators for all components, something that i didnt take care of at all. did you figured that something else was wrong on the main amplifier board ? I do have a new revison of the sevice manual and there is a lot of reworks needed to be done. Those reworks dont apears in any of the schematics posted on this site. I will send it to you. Cheers.
Electronic engineer for automotive market. |
#103 |
Account Disabled
Your board may be different but I see the scimps are still using 6 volts for gate drive. I believe C3 would be 47p, not 4.7p, so it's not that immense a difference, just sufficient to speed it up a little, likely to compensate from the delay induced by level shift through the MPSA42, I would think this value was selected empirically. Hey, rev6, rev7, how different can they be, they both fried ![]() Looking forward to seeing more about this, even though it may be an exercise in futility, I find it highly interesting. |
#104 |
A 47p would be marked 470 then ?
I am always confused with that. 474=0,47u or 470n 473=0,047u or 47n 472=0,0047u or 4.7n 471=0,00047u or 470p 470=0,000047u or 47p 47=4.7p???
#105 |
Hello, and yes, C3 is 47, just like in the schematic.
The datasheet on the IRL640 states that it has a very low voltage requirement for the gate, in fact, the test circuits for the device only use 5V. It isn't like the IRF640, that needs double the voltage! So although the circuit seems inadequate for the HEXFET, it is in fact, about right. I almost wonder if PPL been thinking that the output transistors were IRF640's... they aren't a compatible replacement for IRL640's. |
#106 |
In response to Pat's question regarding the 47 marked capacitor, it's always been my understanding that any 2 digit number on a cap is always that number in pico... so 47 is supposed to be the same as a 470... 47 pico. Since there is a bit of question on this one cap, I will try to get it tested to confirm. I will keep y'all updated on that cap.
Jer |
#107 |
Account Disabled
Yeah reading cap values from markings is confusing as hell because there's no standard method of marking them for any given cap, chances of a screw up are likely, ability to measure them would be great, wish I had it. The other reason is because while looking for a nice decent clear correct reference on this, I haven't found one that didn't screw something up.
Two examples of screw ups I found on what are the nicer sites I saw: 1. "So 100 would be 10pF multiplied by zero i.e. 10pF." He got the right answer, just screwed up the instructions. 2. HM, well, these guys don't let you copy and paste from their site, guess they want recognition for their hard work, so here it is: http://www.radio-electronics.com/inf...itor_codes.php "It can be seen from the tables below"... the tables are above.."that a capacitor with the marking 104J has a value of 10 000pF and has a tolerance of +-5%" At least their tables were right, doesn't serve to teach anyone well when their "worked example" is wrong. It is my understanding as well that when it only shows two digits, then you just take that as the given value in pico farades Your table is perfectly correct until you get to the bottom. In order to get 4.7 out of 47 you have to multiply by 10^-1, as you know, and it does make sense to do because it's simply the next logical step. But the simple and confusing fact is, this is where they break with convention. There is no multiplier given, so as a rule, it doesn't get multiplied, you just have to take it as face value and that it is in pico. So, you're perfectly correct to say that 470=47X10^0=47, but, it is the same thing as simply having it say 47... and they say there's no black magic in electronics. There's three whole pages in the student manual of Art of Electronics dedicated to helping one stand a chance at reading caps properly, even with that aaand the internet at my hand, I find caps that just leave me scratching my head. At least resistors have their act together. Anyway, back to the good stuff. Jeremy can you comment on how poor the drivers power supplies are in your version? Find us some burnt parts Nice looking schematic and dissection as well. I think it would be neat to see you guys get that working half decent, somehow, accomplish what JBL and their ilk could not.Regards |
#108 |
well, in a nutshell, since there are no zeners or other regulators in the amp module, i would say that it relies solely on the external circuit for regulation. I haven't looked into the outside circuit much yet since I isolated the problem with the sub. Also in the same nutshell, from what I do recall looking at, it is strictly unregulated, direct dc straight from the bridge rect. from the step-up transformer. I could be wrong, I only skimmed through the board prior to removing the amplifier unit.
The plan is for me to go through the devices tomorrow. I strongly suspect the op amp is what actually failed, initially, since that came out in 2 parts. BUT, an op amp isn't going to blow my 2A fuse either. There is some arc damage evident between the source and drain of M2 (Q2 on the schematic). With the exception of the ICs, all the semiconductors and resistors test good, and the caps show no signs of mesurable short or blistering, but I haven't tested them extensively, yet. I honestly believe that the circuit is adequate, considering it's application. In anything but a subwoofer, you would notice the difference in the unregulated power supply rails to the driver HEXFETs. Subs can vary in their power as much as 10% and have no real noticable effect to the ear. The biggest downfall to this poor design is the heat dissipation....in this encapsulated and virtually closed design for a heatsink, there is almost no thermal efficency. I'm seriously considering adding a small cooling fan to a custom heatsink assembly with a higher thermal conductivity. Most powered subs rely on the movement of the air from the cone to cool the unit, and as I've read througout the net, these JBLs most often fail when in standby. For that reason I believe it isn't the poor design of the unit, rather, but an unclean signal getting to the unit causing it to stay "ON" but not enough to move the cone and cool. What JBL might have done to prevent this is have a better incomming signal filter to prevent a false "ON" situation. Makes sense to me! (although I have been wrong before) Jer |
#109 |
Hi, if you look closer to the schematic is sent you, there is plenty of dc filtration here and there, as well as a low pass and high pass filter too. C32 is right berore the amp module to filter any dc.
So in your module there was IRL 640? mines were defenitively IRF's. I dont find any data sheets for the IRL's... I would say what make them fry is the absence of proper voltage regulation, and that the gate drivers are powered thru theirs very limit at +6v. If i ever work on that again, my first mods will to add some zener at the vcc of both chips to clip it at anything more than 5.6v. The schematic that you posted, wich is mine but modified, differs very slightly from what i did, and i still believe that i did it right, and that we dont have the same exact boards. At least, part of my job is to reverse the competition products, to see if they have copied my (our) design
#110 |
Account Disabled
Hello,
IRL640? I'll tell ya what the difference is.... ready for this? IR(L)...L= logic level. Vth is 1 to 2 volts. That'll go a long way to keep the mosfets cooler. If you just type "IRL640" into google you'll find the data sheet no problem. http://www.alldatasheet.co.kr/datash...RF/IRL640.html It's not so much that you might hear some difference in power by poor regulation, it is as Pat said that they're running the inverters a little too high, they used to expect them to do the job of a 12V driver, which would be hard on the mosfets. In this case they have an easier load being logic level , but they do have a max voltage and 6 is reaaaal close, it is well beyond their "recommended" max voltage. If their supply is as you say, a small power line surge of say 10%, not uncommon, would be enough to flat line them. Instead of a fan, maybe you can find / make some decent heatsinks for it. Just leaving the epoxy junk out and leaving it in free air might be a big difference in that regard too. I bet your op amps would have been fine, they're very robust devices from my experience. Anyway, keep us posted, something is wrong with it ![]() Regards Chris |
| Pre-design of my class D amp...PB12 related | pat allen | Class D | 2 | 14th October 2005 04:17 PM |
| FS: SVS PB12-ISD/2 SUBWOOFER! **Local Pickup In Florida** | chops | Swap Meet | 3 | 10th July 2005 04:37 PM |
| JBL PB12 dead? | turkish621 | Subwoofers | 10 | 28th May 2005 01:11 AM |
