ClassD with Solid State Relay?
Old 24th December 2004, 12:40 PM   #1
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Default ClassD with Solid State Relay?
I just got back from local electronic market. I saw a "Solid State Relay".
ClassD PWM type power amp uses final transistor as a switch only, on and off with varying width. A relay does the same thing, only on and off.
I dont know the spec of this SS relay, but if its capable of 500khz, I think it can be made classD power amp, with big supply rail and big current (big amp).
Does anyone has tried it before?
Old 24th December 2004, 11:32 PM   #2
IVX is offline IVX  Russian Federation
IVX's Avatar
hi lumanauw,
Usually solid state relays is slow too much (several mS), but you can use other optical solution for the class D- TLP250 (or like), which 1000 times faster vs SS relay.
Best regards,
E1.
Old 27th December 2004, 07:07 AM   #3
phase_accurate is offline phase_accurate
They are usually made to switch 60/60 Hz mains and include things like zero crossing detection.
You can't use them for class-d amps.
They are a nice thing however for remotely switching-on PSUs etc.
Charles
Old 30th December 2004, 12:40 AM   #4
subwo1 is offline subwo1  United States
subwo1's Avatar
H11Fx is a pretty cool optocoupler which may be worthwhile to tinker with as well.
USMPS
http://groups.yahoo.com/group/switchmode/
ClassD with Solid State Relay?Hide this!Advertise here!
using a solid-state relay jarthel Parts 1 1st September 2006 04:31 AM
How to make a solid state relay? Magura Parts 14 13th September 2005 04:11 PM
Solid state relay with NO and NC available ? Av-engineer Parts 2 13th October 2004 11:14 AM
solid state relay karma Pass Labs 5 31st March 2003 12:33 PM
What is a solid state relay? Bronze Everything Else 6 21st December 2002 08:48 PM
Copyright ©1999-2017 diyAudio
