Charles, we need your help on feedback in single supply Class-D - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 12th January 2005, 02:15 AM   #11
Kenshin is offline Kenshin  China
Kenshin's Avatar
passive intergrator v.s. op amp:which will produce less distortion?
the passive one produces a slightly non-linear triangle,but the nonlinear effects is very low when the level of triangle is small.
(maybe the harmonics involved can be analysised by taylor series expansion,but i haven't do any calculations yet.)
Some peple reports that a hyersis modulator made of 555 timer,with a hyersis of VCC/3,produces only 0.8%(maybe 2.5%) THD.
op amp has finite SR and it's sensitive to noise and TIM.
fast op amp can prevent this,but they are also expensive.
Originally posted by phase_accurate
So you will definitely need another op-amp for the integrator. There would also be a possibility for doing this just passively. But apart from simplicity I don't see any advantages of doing so.
Old 12th January 2005, 07:09 AM   #12
I think you will have a shoot-thru problem.
The two drivers in 2110 are independent, so they may overlap, and there's nothing in your circuit that creates dead-time.
Old 12th January 2005, 07:30 AM   #13
Kenshin's Avatar
is there any gate drive ICs with internal dead-time?
Old 12th January 2005, 08:35 AM   #14
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
They're being driven by a pair of gates which are splitting the signal, so the drive signals won't overlap.
The dead time is created internally by the driver's turn on prop. delay Vs turn off prop delay, this is all that IR uses in their reference design.
Dead time is a bad thing! (may the flames begin)
Has anyone tried one of those predictive gate drivers yet?
Old 12th January 2005, 08:37 AM   #15
ssanmor is offline ssanmor  Spain
mmmm, workhorse, your design resembles a lot to what I posted in this forum about 1 year ago or more (LM6172 triangle generator, XOR gates at IR2110 input, LM319 comparator...
I did some experimentation and also with symmetric supplies and no level shift, with all (triangle gen, error opamp and comparator) using a single supply referenced to Vss, with of course capacitive coupling at the input, but had variable offset problems and distortion figures were not very good so I abandoned that approach although it was much simpler.
If that's an experiment and you are doing it to learn and for personal use, no problem for me (that's what this forum was created for).
Have luck.
Old 15th January 2005, 07:48 AM   #16
subwo1 is offline subwo1  United States
subwo1's Avatar
I thought the IR211x had some built-in dead time. My impression is that dead time is bad, though it may be better to margin toward DT than toward cross conduction in most cases these days. But, DT does raise distortion and noise, so I can understand your interest in adaptive DT. I appreciate how you have shed light upon the problems concerning MOSFET body diode conduction, too.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 15th January 2005, 10:50 AM   #17
Account Disabled
Why thank you. I appreciate that you're one of the guys who brought it to my attention.
It seems clear both overlap and lots of dead time aren't the answer and so the middle ground must be found. Predictive delay is said to "eliminate" body diode conduction! I'm not that picky, adaptive would do fine for now, and the effort would have big payoffs, aside from THD and EMI, you gain a very robust gate drive that has an iron grip on any mosfet you want to swap in your circuit.. we don't drive our cars blind, why do it with mosfets?
The benefits of doing it adaptively are many. Drawback is complexity (DIY'rs don't seem to care about cost). Lot's of IC drivers have used it for awhile (late 80's?)..they seem geared towards low voltage regulators, and I really hate being a slave to an IC, (I have some ideas..) but for now the LM5401 seems rather quick, with nicely matched, short delays and good for 100V, with a full bridge that's respectable. It has a single input, so if you start off opposite phased split signals that can't overlap, a full bridge should be easy.
Everyone seems to like using the IR2XXX stuff, but the delays and matching are horrible, sure it's good to 600V, but I haven't seen that put to use either?
Hopefully they'll realise there's a market for better drivers for something other than notebook, PDA and cell phones!
Old 15th January 2005, 06:44 PM   #18
subwo1's Avatar
Thanks, too. The LM5401 may not be a bad option. I may try some.
Since I mainly play around with power
supplies, I am actually quite attached to the IR211x,
though. I like the pin layout because it enables me to easily keep the
driver sections close to the MOSFETs. I have gotten its bootstrapped supply up to about 500v already. Another time, I blew one because I forgot to connect the common to the upper MOSFET source, or some such mistake, and the bootstrap supply floated up to oblivion.
I'm probably not the average DIYer since I do tend to seek value. I still spend a lot on parts, nonetheless. I think it is that I like
circuits that use easily available parts, and not too many of them as well. I often seek a compromise in design which may cost a little more but also make a design smaller or more forgiving.
I would be afraid concerning newly developed ICs that they will only be
available in surface mount. The only surface mount items I tolerate are the S0-8 MOSFETs. I may be able to avoid them, even, on the project I am working on now if switching times can be slower and gentler with small die MOSFETs.
USMPS
Old 17th January 2005, 06:44 PM   #19
Account Disabled
Here's a fine example of the regenerative affect acting to snap on the high side mosfets, you can also see the loading of the discrete driver.
Sadly it seems to function best as a driver when heavily loaded, I've found that a very fine balance must be achieved, because it doesn't seem possible to have non overlapping signals unless the driver is partly loaded down. This causes gate signal amplitude to vary with duty cycle. It would likely therefore be wise to select a higher drive voltage, like 15V, to lessen the detrimental affects of the gate drive signals and help maintain a constant RDSon.
To reduce the risk of overlap, it is easier to use very low current to switch the drivers with, however, too low a current and it wont' switch fast enough. This is additional to the dimensioning of the driver values to create loading as well (you need both a lightly loaded driver, and weak signals), both techniques serve to reduce overlap of the gate signals. So it is obviously only an optimal driver in terms of reduced part count, and can be made to function, although, not very well, and not without risk.
The reason to have slow turn on is to give the slow body diodes time to recover and become blocking before turning on the opposing mosfet into it.
This seems to be a half solution. Slowing of the turn on signal increases dissipation in the mosfet, and I believe helps to increase THD as well. Futhermore, it seems the regenerative affect operating on the high side mosfet's gate works against the solution.
I view all the above as strong arguments for the case of adaptive delay.
The attached gate drive signals are from simulation of a full bridge done using seperate high side Vdc sources. You can see that as loaded as it is, there's still a worrysome amount of overlap, requiring lowered current from the comparator output, but as I said that is a compromise in switching performance.
In conclusion, simple discrete drivers suck.
Old 17th January 2005, 07:32 PM   #20
subwo1's Avatar
Looks almost identical to a small signal transistor common emitter circuit with about a 10K ohm pull-up on the collector. I used such as inputs to the IR211x a while back. I even had such a waveform as the output of the ubiquitous two transistor multivibrator directly feeding the input gates of the 211x, providing a drive waveform with built-in dead time for an unregulated off-line AC to DC converter.
You can also obtain such a waveform from the output of the 6n137 optocoupler, but the usefulness of it is limited by the fact that when the opto is off, the output is high. For that reason, it tends to destroy MOSFETs unless current is supplied to the emitter diodes of the optos before power is applied to the MOSFETs. The open-collector outputs of the optos need to be pulled low first.
USMPS
Single supply class D modules? theAnonymous1 Class D 3 27th September 2005 07:48 PM
Single Differential Non-feedback lumanauw Solid State 3 5th September 2004 02:29 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Copyright 1999-2017 diyAudio
