Help with feedback
Help with feedback
Old 26th November 2004, 08:36 AM   #1
Pierre is offline Pierre  France
Banned
Default Help with feedback
As an experimenter with Class-D amplifiers, I have found that it is not easy to properly design the feedback network when you want to include the LC output filter on it, and make the amp remain estable.
I think that some designs (self-osc or UCD) use positive or "hysteretical" feedback, but I am not interested on that, but on designing the compensation network for a basic PWM (triangle based) amplifier with negative feedback, including a single LC network (2nd order lowpass).
I have seen that there is a so-called "leapfrog" method, but I am not able to extract the phisical sense and design procedure for that case from the PDF. Are there some basic guidelines or simple explanations?
Phase_accurate, I have seen you are kind of an expert in these issues, can you help me, please?
Thanks!
Old 8th December 2004, 06:59 AM   #2
phase_accurate is offline phase_accurate
Salut Pierre
Sorry for not responding earlier. I have been on holiday. In the meantime also my hotmail account was erased due to not using it.
If you have e-mailed me you message might have got lost.
There are many ways to build the triangle-based modulator itself. Could you tell us something about the ciscuit decisions that you have made so far ? Are you willing to share the final design ? If so I am of couse willing to assist.
Charles
Old 8th December 2004, 09:24 PM   #3
Banned
Thanks for the help offering and don't worry for the delay, Charles.
My set-up is, by the moment, a simple experiment:
An error opamp configured as inverting amplifier, the signal enters via a resistor to the inv. input. The output goes to a comparator, and the other input of the comparator receives the triangle.
The output filter values are 20uH and 440nF.
What I would like is to include a 2nd order filter (LC) into the loop so the output impedance is reduced and the freq. response is made almost independent on the load, and the overall response is similar to a 1st order lowpass, while reducing distortion due to non-linearities of the ouput filter.
If you could give general design guidelines on how to design the feedback network to compensate for the filter phase shift, I think it could be very useful for any Class-D amp designer.
thanks!
Old 9th December 2004, 06:40 AM   #4
Before we try to close the loop around everything: Does everything look fine open-loop. I.e. no ringing on the switching signal (with and without load) ?
How does it look like if you close the loop around the the switching stage (what this topology is meant to be used like) ?
If everything is working fine so far (important, if you don't want to do annoying debugging) we need to know the component values of your integrator and the gain of the switching stage (basically the PSU/trinangle-amplitude voltage-ratio).
Then we are able to rearrange the loop filter to take the output filter into consideration.
Charles
Old 9th December 2004, 08:22 AM   #5
Banned
Thanks for your help, Charles.
Well, by now I have a 68k resistor between mosfet's output , with input resistor to the error opamp of 2k. (looking for a 30dB gain).
The output stage gain is 15, aprox. (6Vpp triangle with +/-45v supply rails).
The error opamp (integrator) capacitor is 470pF, and a 100K resistor in parallel, to improve DC offset, etc.
Now the loop is closed aroung switching stage. With this setup and a 10ohm in series with 330n zobel network, the -speaker- output has ringing only with light loads (above 20 ohms or so), overshoot for 8 ohms and very clean below that.
Is this a good start point?
Old 9th December 2004, 12:30 PM   #6
What I meant was the PWM signal itself. Things like ringing etc can lead to interesting effects like increased THD when the loop is closed (instead of the contrary). The output-signal of the comparator must also look clean, without glitches etc, since this can lead to premature death of mosfet-drivers.
One important thing I forgot to ask: What is your carrier frequency ?
And another point: We are free to change the actual closed-loop cutoff frequency within some limits. Do you want to do this ?
Charles
Old 9th December 2004, 02:00 PM   #7
Banned
Ah, ok.
The PWM signal looks very good. The rise and fall times are about 70ns and there is almost no overshoot. So does the comparator output.
About the operating frequency, I feel comfortable with 260-300KHz, although I can vary this. (after all, this is an experiment!)
About the cutoff frequency, I would like to have about 30KHz at -3dB for 2ohm to 8ohm loads.
What do you think about my Zobel network? In my simulations it actually helps damping things when there is no load.
If I have time I will try to post some photos of the PWM and play a bit with the feedback network so I can give more details. My primary concern when closing the loop around filter is estability.
Thanks, Charles, for helping us in demystifying the "feedback after filter" problem!
Old 9th December 2004, 02:51 PM   #8
I also think that it is a good idea to use it but I would maybe lower the capacitor's value. One critical situation with after-filter NFB takeoff is the no-load situation. Though it might not be as severe in practice as in simulations, since practical filter parts are always lossy. But it would be a good idea to switch the thing on for the first time (i.e. the first time using after-filter NFB when it worked beforehand using before-filter NFB) WITH a resistive load connected.
As a start I would use the following:
1.) A 47 pF cap in parallel with your 68 k feedback resistor. This gives a phase-lead in the closed-loop and determines the overall upper cutoff-frequency.
2.) Decrease the Integrator cap to 330 pF since this will give you more NFB. With this value there is still some marging, so you won't get into problems when lowering the carrier-frequency below 260 kHz.
3.) Use a resistor of 10 k in series with said integrator cap. This will make your integrator (actually a PT1) into a PI. The FR of this "turns flat" at the output-filter pole frequency at said dimensioning.
4.) Play around with the integrator's parallel resistor. A larger one will lead to more NFB and lower THD at low frequencies. Smaller values however will lead to a more constant NFB factor throughout the audio range (and therefore more constant THD behaviour over the input- frequency) and faster overload recovery. Your 100 k is about the largest I would recommend. Maybe you will try with 47 k as an alternative.
You might actually try it first on the simulator.
And one more thing: Have fun !
Charles
Old 9th December 2004, 06:58 PM   #9
Banned
Thanks!
It's funny! Just this afternoon I was playing with the simulator a little bit. Although my model doesn't include the switching nature of the amplifier (it is just an opamp -the integrator- , then a linear gain -the switching stage gain-, and then the filter), I hope the results can be extrapolated.
Before reading this, I have tried by adding a 82pF capacitor in parallel with the 68k resistor, and it has solved almost all the problems. I haven't currently added 10k in series with the integrator cap, but I will try your suggestion to see its effect. I had also lowered the 100k to 47k and I now I like it more.
Let's see if I can try this in real life as soon as possible, and let's see also if the pulse response is as good as in the simulation, as well as the freq. response, that has become almost load independent!
Thank you very much for your help. Should I find any more optimizations, I will publish them here, no doubt.
I think that these guidelines can help a lot of Class-D designers.
Cheers
Old 10th December 2004, 05:57 AM   #10
Banned
Hi, Charles.
I added a resistor in series with the integrator cap as you suggested, and now the simulated freq. response is better (no ringing) with no load, so it does improve things.
A last question before putting hands into the lab: how can I measure phase margin in the simulation? Sorry, but I have forgotten the details since I studied it, so if you want to remind me... can I measure it in open loop or is it necessary to introduce an excitation while maintaining it close-loop, as it is done when designing power supplies compensation?
What is a good phase margin figure for these kind of amps?
If you are so kind to explain the procedure I (and many others) would be very pleased.
Thanks!
Help with feedbackHide this!Advertise here!
'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' mikeks Solid State 62 20th July 2005 08:03 AM
