Sonic Impact Amplifier
Hello Gents, and welcome to my first post!
I recently bought the Sonic Impact class T amplifier and immediately opened it up. I am in the process of putting in into a nicer case and such, much like another post here.
I fired it up, and it does sound very nice.
My question is how could I go about hooking up a subwoofer with this amplifier.
The sub is self powered. Do I need a cross over of some type, and what would you recommend?
Liver
If you have a self-powered sub, it should have a standard style plate amp in it that has provisions for inputting from an amp/receiver (push connectors) and then another set back out to your speakers. If not, you should consider buying a cheap plate amp from Part Express etc and using it with an existing sub or build one. Not sure by your post if you have a sub or need one.
amt
