delay time is it normal for class d amps - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 16th November 2004, 04:51 AM   #1
Default delay time is it normal for class d amps
Hey i have a orion xtr pro 1000 class d amp and it has a delay time on it i don't know why but it's almost 2 seconds and i bought this thing new. I have never use class d before first time, is it a normal thing for it to do this? its the time from the amp to the sub or the deck to the sub
Old 7th December 2004, 05:04 AM   #2
Do you mean it takes 2 seconds from the remote line being energized to when the amplifier starts amplifying? If so, then that is totally normal. It is most likely a relay to allow the power supply rails to raise before the amp starts. Most likely because it's a regulated supply. Don't worry about it
B+ time delay relay cbutterworth Tubes / Valves 24 31st August 2011 01:53 PM
Time delay start board for tube amps gjo Tubes / Valves 4 26th November 2008 04:23 AM
time delay with 2 amps? thedman Solid State 2 2nd November 2007 01:22 PM
adjustable time delay back Analog Line Level 18 1st March 2006 09:01 AM
Time delay without the $600+ expense?? HobbesJunior Parts 7 15th November 2003 03:19 AM
Copyright 1999-2017 diyAudio
