Inside Sony AVD-S10 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 14th November 2004, 12:14 PM   #1
Default Inside Sony AVD-S10
Hi all,
Here is some Sony S-master pic. I am thinking of modding, mostly just changing caps. Any advise is welcomed. Thanks
Old 14th November 2004, 12:15 PM   #2
The power supply.
Old 14th November 2004, 12:37 PM   #3
The amp stage with S-Master
1st stage is CXD9634.
2nd stage is CXD9646.
And large coil and caps for the LPF.
Old 14th November 2004, 12:38 PM   #4
JohnW is offline JohnW  Czech Republic
JohnW's Avatar
Hi ChuckT,
I wouldn’t change the caps in the PSU unless you know what your doing – SMPS require Low ESR caps, and changing types / values could upset the Feedback loop.
However the caps on the Amplifier board could benefit from improvement.
1. Increase C313 (main HBridge supply) leave the existing cap on the PCB, but add an external larger part (can be fitted across the connecter CN300
2. Fit OSCON’s in positions, C312, C301, C326, C336, C350, C388, C392, C325, C320, C329
There’s a guy selling bags of OSCON caps on a stand in Sham Shui Po (electronics market) for HK$1 each!
Buy the 470uF 6V3 and fit in the above position (where the voltage rating will allow).
The PCB is very poorly design (very poor ground plane & terrible HF decoupling), but the above modifications will improve the audio quality.
The S-master modulator can achieve a dynamic range of just shy of –120dB; it’s not a bad design.
We should go for drink one evening in Wan Chai,
John
Time is my worst enemy!
Old 14th November 2004, 12:38 PM   #5
CXD9646
Old 14th November 2004, 12:46 PM   #6
Wow, that was a quick reply. And from HK too.
Thanks, I know it is not wise to mod a SMPS. I normally just replace the last cap in the output.
Do you have a schematics?
Yes, I am alway happy to meet a local fellow moder.
PM me and we'll discuss.
I have a lot of Oscon in my box, so really I can start immediately.
What values do you recommend to replay the 100uf/10V.
Actually, I just got this gear yesterday.
Old 14th November 2004, 12:50 PM   #7
Ops, read too fast.
I don't have 470uf/6.3v. The max I have is 150uf/16v.
There are various values, I am not sure using such a high cap value is a good idea.
Old 14th November 2004, 01:02 PM   #8
JohnW's Avatar
Hi ChuckT,
No problem to fit as large (Oscon) cap as you can, although there physcial size will be the limiting factor. The LV regulators are very noisy (on the Clock and digital supplies around the modulators), the larger caps well help reduce this.
The output devices are "badged" Sankan devices, and the modulators are Fab. by Renisis (Ex Mitsubishi).
I'm sorry I don't have the circuit diagram, I bought a unit to Eval. the modulator (Sony DAV-S400, which appears to be very similar apart from the Video IO / Audio IO / Tuner Bd).
John
Old 15th November 2004, 05:36 PM   #9
Hi John,
What's with all the shielding.
There are 2 copper shield under the amp board and shields around the 8 coils.
The small shield under the amp board cover the crystal the 2 s-master chips. The large one covers half the underside (not shown in pic).
Old 15th November 2004, 05:42 PM   #10
Here is modded pic, only the front 2 channel caps are changed. BG hi-q for the cxd9634 and pana fc, Oscon for the power chip.
I wonder if replacing the brownish red caps (mkt?) with small BG hi-q is a good idea.
Sony CDP-337ESD v Sony CDP-X33ES which is best? eldarvanyar Digital Source 0 10th January 2008 12:04 PM
Copyright ©1999-2017 diyAudio
