Thinking of starting a 'new' Class D design.
Old 8th November 2004, 03:11 PM   #1
Genomerics is offline Genomerics  United Kingdom
Account Disabled
Lightbulb Thinking of starting a 'new' Class D design.
I don't really know what to say but I need a prod up the behind to actually get down and do this..... please give me one.
I'll be posting the design info at...
http://groups.yahoo.com/group/classdamplifier/
The rest is open to discussion.
I'm going to be doing a clocked thing using PWM with multiple stages operated in phase shifted parallel, if that makes sense.
I've got LTspice and some other bits as well as schematic capture and PCB design software (I can release Gerbers). I'll try to present the documentation in PDF format
Ask some questions and we'll see how it goes. All and any input appreciated.
DNA
Old 13th November 2004, 05:04 AM   #2
thespeakerguy is offline thespeakerguy
Send a message via Yahoo to thespeakerguy
Default phase shifted parallel = poly phase?
Do you mean it will be set up like a multi phase switcher, similar to the latest CPU power supplies?
Old 13th November 2004, 09:15 PM   #3
Account Disabled
Default Re: phase shifted parallel = poly phase?
Yes.
I'll be using a number of 'modules' to share the output.
Each will be operated using current mode control and provide its share of the output current according to an overall demand signal.
DNA
Old 14th November 2004, 03:49 AM   #4
EWorkshop1708 is offline EWorkshop1708  United States
Awesome, I'd like to see this in action
Old 17th November 2004, 03:36 PM   #5
ClassDunce is offline ClassDunce  Wake Island
I played around with a multi phase design for a while but always found that the changing output impedance resulted in distortion folding down into the audio band. To see this effect in simulation I had to add non-linear inductors and model speaker back EMF effects.
I'm sure there are solutions for these problems but I gave up on it because there did not seem to be any advantage and there are a lot of added costs.
ClassDunce
Old 17th November 2004, 04:50 PM   #6
Account Disabled
ClassDunce
I'm not sure I understand what you are saying.
However, if you want to do a 'multi phase' design you have to bear in mind that the filter inductors in each stage integrate the volt seconds applied to them to give a final output current.
If you simply apply the same, but phase shifted, pwm signal to each stage then it is likely that one of the stages will 'hog' the output current because off differential delays and switching times.
If you add a current mode control loop to each stage then you can force them to share the current.
DNA
Old 10th May 2005, 11:04 AM   #7
Account Disabled
Default Long time, haven't done much
Got back to it and started writing some of the theory behind what I'm doing.
Done a bit of design work to try and get things together and then modelled things in spice using 'proper' bits and pieces.
The piccy is an FFT of four stages operated in parallel with current sharing. The base modulator frequency is 200KHz for an effective 800KHz.
You can see a bit of a lump at 200KHz with the rest of the switching hash up at 800KHz. These components are 40dB down or about 10mV rms(?). That's one of the reasons for doing it this way.
This is 1.5Vpp in for 60Vpp out at 10KHz off 80V rails. Mosfets are IRF640/9640.
If the theory, and small signal model, agree with the switching model then the -3dB bandwidth is about 200KHz. I'd be bothered about current slew rate limiting.
As is always the case with spice.... don't believe everything you see. I'm fairly confident that things are not too wide of the mark.
DNA
Old 10th May 2005, 11:36 AM   #8
Account Disabled
This is the output voltage at start up along with the stage currents.
Each stage here is modelled the same as all the others but D gets caught first and is then brought back into line with the others by the control loops.
The spikey bits are body source diode reverse recovery.
DNA
Old 10th May 2005, 12:04 PM   #9
Account Disabled
Here's the 10KHz square wave response.
The peaking is present in the linear model as well, I've had to clamp the voltage error amplifier to tame the result in the switching model.
Oh, it's a 6R resistive load.
DNA
Old 10th May 2005, 12:05 PM   #10
Jaka Racman is offline Jaka Racman  Slovenia
may I suggest that you take a serious look at Bruno's US pat no. 6,803,816. His method of using autotransformers for automatic current sharing between phases of multiphase system is a very good idea. I will try to implement it in multiphase nonsynchronous buck converer where I expect it will alow me to reduce volume of magnetics components by more than half.
I suggest you do some simulations. Coupling coefficient can be as high as 0.99997 (that is what I have measured on my prototypes). Maybe you will find that you do not need output filter at all.
Best regards,
Jaka Racman
Thinking of starting a 'new' Class D design.Hide this!Advertise here!
Kelly DC motor controller group buy - anyone thinking of starting one for this year? Dan_ed Group Buys 50 27th February 2010 03:05 PM
Thinking of starting a new project, needing some advice Jacobus Full Range 3 1st February 2006 09:28 PM
New guy on the block thinking class A mashaffer Solid State 71 3rd August 2004 02:14 PM
Copyright ©1999-2017 diyAudio
