Zappulse PSU wiring problem - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 31st October 2004, 09:58 AM   #31
Hi Ed,
I was refereing to the issue in the do's and dont's section http://www.lcaudio.dk/com/index.php?page=63
If I understood correctly the (potential) problem doesnot exist if you have 1 PS.
I know of some people having build monoblocks (without the sync module) with no problem whatso-ever. Others are less lucky and hear some soft (high frequency) noise. The exact reason for this I don't know (maybe sensitive speakers are also are more problematic). I think the sync generator is not that expensve, so why take chances (although using them for lows only maybe makes it less important)?
Also (if I understand correctly) I can place the Zappulse modules a little farther apart (so there is less interaction/influance between them). Of course the will be still in the same enclosure.
Is that all there is?
Old 31st October 2004, 02:30 PM   #32
wytco0 is offline wytco0  United Kingdom
wytco0: Do you mean something like this?
http://www.lcaudio.dk/wytco.gif
Lars ,
Firstly thank you for looking into this and for doing so on a Sunday when you are on holiday, it's much appreciated.
That diagram is excellent, I know you have explained the AC but including that would also help.
You have labeled the DC as +-60 which I assume is the Zapulse voltage but I think its a function of the transformer used so more general voltage labeling might be better?
PS you mentioned that torroids are not centre tap and I had a look at the one I have, I hadn't noticed it before but as you suggested the centre tap is actually 2 wires tied together and put in a single sleeve, I guess I could have separated them but my new transformers are arriving tomorrow !
Transformer wiring problem ebenai Chip Amps 3 7th May 2007 06:56 PM
tranformer wiring problem ebenai Power Supplies 2 7th May 2007 08:35 AM
Basic wiring problem Bobhof Parts 2 22nd April 2006 02:51 PM
Need hEEEEEEEElp!!!! wiring problem!!!! guitaratiug Parts 2 30th October 2005 10:10 PM
A wiring thought problem Xylenz Multi-Way 9 23rd January 2003 04:58 PM
Copyright 1999-2017 diyAudio
