| Class D Switching Power Amplifiers and Power D/A conversion |
#21 | |
dave |
#22 | |
What are you BTW trying to achieve with your soundcard test? You do know that SMPS's use (almost) only square wave?! I would suggest you to borrow a good SMPS cookbook from the library to get acquainted with the technology, or why not search the web first. And when starting to make some SMPS you are (IMO) quite dependet of an oscilloscope, if you dont have an inductance meter you can naimly use the scope also for measuring the inductance in your choke etc, if you know how to do, good luck!
#23 |
i'm working on a car amp also
![]() i'm making a power supply that consists of an H bridge that will be connected to a transformer ,i think thats the easiest way because u can do that with no scope BTW if i will use a regular coil transformer that suppose to work at 50hz will it be ok to use it for 100hz or higher? |
#24 | |||
I used my core's cross section and assumed ferite material, and an online toroid calculator to find the primary wind number for 22khz. The core works fine, all I was curious about was the odd dmm readings. Quote:
#25 | |
dave |
| How hot do E-cores get? | Dr.EM | Parts | 5 | 26th January 2009 10:13 PM |
| Double C Cores | TheMooN | Tubes / Valves | 8 | 20th August 2007 10:01 PM |
| Where to buy large R cores. | Tweeker | Parts | 0 | 24th January 2006 05:18 AM |
| pot cores | sunrise | Parts | 4 | 20th October 2005 09:52 PM |
| for R-cores | Mecanp | Digital Source | 8 | 14th February 2003 12:17 PM |
| Page generated in 0.08784 seconds (75.29% PHP - 24.71% MySQL) with 11 queries |
