Coldn't resist: feedback from 4th order lowpass !!
Old 14th October 2004, 06:12 AM   #1
phase_accurate is offline phase_accurate
Default Coldn't resist: feedback from 4th order lowpass !!
Because there are still many out there who think that it is almost impossible to build PWM amps using post-filter NFB takeoff - I made an attempt to calculate such an NFB loop. I went to the extreme and took a fourth order output filter (f3=50 kHz, Bessel). I publish it here even at the risk that someone will go and patent it.
Just some remarks:
1.) I actually know that real life is real life and simulations are just simulations so I don't want any discussions on that subject.
2.) I know the advantages of self oscillating topologies. I used a carrier-based one because "I come from there" and also because there are many ICs and other solutions for carrier-based class-d around that still use the same boring old NFB topologies.
3.) The same transfer functions can be achieved with alternative circuits. I just used the second topology that crossed my mind. These may even perform better in real life than the one here because they would need less op-amps or put less stress on them. I think I don't have to mention that careful choice of op-amps would be critical in real life.
Because my version of P-SPICE is very restricted I used the voltage-controlled voltage-source model insted of op-amps. It is of course possible to use multiple nested feedback loops instead of the single-loop topology presented here.
4.) I by myself would most probably not build a class-d amp with fourth-order filter because all the component tolerances are much tighter than they would be with a 2nd order filter. Carrier suppresion of 2nd order filters is also sufficient in most cases.
If you have a look a the schematic you can see a classic PID around E1. This one is responsible to build a first-order behaviour, together with one pole-pair of the output filter (ca 70 kHz, Q=0.52).
The second pole-pair (approx 80 kHz, Q=0.8) is dealt with by the circuit around E37 and E10 with the transfer function s^2T^2 + sT/Q + 1.
Because the transfer-function of the feedback-branch is a PD the closed-loop frequency response is a first-order lowpass. I tried with different loads between 2 Ohms and 1 k (nominal = 6 Ohms) and the response deviation was around 0.3 dB at 20 kHz. Deviations were a little "adventurous" above 30 kHz, but this wouldn't be that much of a problem with "normal" loads and clever choice of Zobel values.
On the open-loop gain diagram one can see that the whole loop has a first-order behaviour (well, almost) and the unity-gain point is 200 kHz approx. Phase-marging is 80 degrees approx !
The simulation I would trust the least is the transient analysis (i.e. the THD part to be exact). One can see the output signal when driven 20 dB below full output. There is not very much of the carrier left over ! The FFT shows that all harmonics of the "payload" are suppressed by more than 80 dB.
While the topology as such would theoretically work it is still not complete and it would show a "dangerous" restriction, depending on the input signal. I will elaborate on this later. Everybody is invited though to find that one out by himself in the meantime !
Charles
Old 14th October 2004, 07:30 AM   #2
Jaka Racman is offline Jaka Racman  Slovenia
Hi Charles,
Thank you very much for sharing your effort. Can I suggest two other tests to try with your circuit?
First is a single unipolar square pulse response. I usually simulate with 0V to 1V 100us or 200us wide pulse. You might change output load resistance and add some load capacitance to see susceptibility of your design to the real loudspeaker loads.
Another test would be to put 1mA AC generator in parallel with the load and plot the AC transfer function from output back to the input of the PWM modulator E23. The reason for the second test is that I found my past design vey susceptible to the switching spikes that were induced in the filter itself and in the feedback path. Good layout might have prevented that, but I was forced to put six channels on a single Eurocard.
BTW, is the problem with your circuit related to the possible clipping of the opamps?
Best regards,
Jaka Racman
Old 14th October 2004, 07:33 AM   #3
Yes and no ! It also has something to do with the first test that you suggested !
Charles
Old 14th October 2004, 02:20 PM   #4
subwo1 is offline subwo1  United States
subwo1's Avatar
Hi phase_accurate
I think it was great that put together this simulation. I too may use a carrier-based approach because I have not decided on the best set-up for my situation.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 14th October 2004, 06:36 PM   #5
Default The secret:
The circuit uses zeoes to cancel the output filters poles in advance. The closed loop has a behaviour of a 1st ordee lowpass after the bottleneck of a 4th order filter.
This is asking for trouble with fast transients and/or strong high-frequency content. Therefore one has to consider an additional lowpass filter before the amp, depending on application (a CD player wouldn't mean real danger but DVD-A and SACD probably could).
Charles
Old 15th October 2004, 11:24 AM   #6
Thats how it would behave with a lowpass filter "in front". The filter is designed such that the overall response of the amp would be the same as the output filter alone would give.
One can see that the transient overload problem is significantely reduced (10 kHZ rectangular).
Charles
Old 15th October 2004, 12:12 PM   #7
skippy is offline skippy  United Kingdom
What max and min delays are you assuming through the amplifier's forward path?
Old 15th October 2004, 01:42 PM   #8
Are you actually talking about the open-loop behaviour of the forward-path itself or do you want to know the behaviour of the complete topology with the loop closed ?
Charles
Old 15th October 2004, 01:44 PM   #9
I want to know about the open-loop behaviour of the forward path.
Old 15th October 2004, 02:08 PM   #10
Here you can see the linear simulation of the forward path with the input of the feedback branch shorted to ground. The PWM modulator would of course introduce some additional dead-time delay.
Charles
Coldn't resist: feedback from 4th order lowpass !!Hide this!Advertise here!
6th Order Bandpass HT Sub, would like some feedback pjpoes Subwoofers 2 3rd September 2008 02:55 AM
First-Order Lowpass Filter with a Cap Taterworks Multi-Way 6 14th October 2007 02:55 PM
4th order lowpass with one transistor AudioAngel Solid State 2 18th April 2007 06:42 PM
1st attempt of 2nd order active lowpass filter failed, please advise SimontY Software Tools 111 15th February 2005 11:32 PM
Couldn't resist this is too funny corryn00 The Lounge 0 31st January 2005 05:16 AM
