diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   Alternative modulation schemes for class d amps (http://www.diyaudio.com/forums/class-d/42371-alternative-modulation-schemes-class-amps.html)
Nirav Desai 11th October 2004 10:12 AM
Can we use modulation schemes like pulse position modulation, sigma-delata modulation for the class d amps instead of the usual pwm? can anyone suggest some resource material on this.
phase_accurate 11th October 2004 08:54 PM
The Sharp SM-SX100 is using delta sigma modulation. Also the Tripath amps use delta-sigma modulation.
Some self-oscillating class-d amps using hysteresis modulation are said to use sigma-delta modulation by their constructors.
Charles
Nirav Desai 12th October 2004 02:45 AM
I would like to get some resource material on practical circuits using sigma-delta modulation in class d amps. can anyone help.
analogspiceman 12th October 2004 03:24 AM
There was a recent thread on this subject right here on this forum: Non clocked (e.g. free running, self oscillating) class d
Check it out. It covers why and how free running class d amp oscillate. If you have any further question just post them to that thread.
Regards -- analog(spiceman)
Kenshin 9th January 2005 12:21 PM
That's Pulse Density Modulation (PDM).
just insert a D flip-flop between the CMP and gate driver,then drive it with a clock pulse of several MHz,that is OK.
but PDM need a switching frequency higher than hyerstis modulation -- that's not ecomic.
a modulator of high order may be better.
SHARP's HIFI equipment uses a modulator of 7th order!
phase_accurate 10th January 2005 09:19 AM
2 Attachment(s)
The problem of high switching frequencies is only a problem for no or very low input signal levels.
Enclosed you will find the simulation of a hypothetical class-d amp using SD modulation. The signal frequency is 40 kHz. One can clearly see the phase of the sinusoid lagging behind the switching pattern due to the output filter.
phase_accurate 10th January 2005 09:26 AM
2 Attachment(s)
And now without input signal:
Resources saved on this page: MySQL 18.75%
