| Class D Switching Power Amplifiers and Power D/A conversion |
#81 | |
because that's how I do things - I overbuild them. They work for me in all other applications. I'll also use transformers about 50% to 100% larger than he recommends. Why? Well, it won't have a negative impact, and I can't imagine how an amp can deliver high current for more than a moment if the transformer can't feed those dinky little caps with fresh juice in a hurry. Heck, i'll double up on the capacitance as well. But, hey, feel free not to do this. I'm sure it'll work just fine in the generic config. Peter |
#82 |
I understand; just wondered if there was some specific reason. Interested to hear how your amp turns out!
best of luck.... |
#83 |
Hey Bruno,
Could you look at this and tell me whether I Get It: Power supply pumping in class-D amplifiers occurs when the output delivers DC or very low frequencies, nicht wahr? In the case of woofers with 2 voice coils, and assuming 2 UcDs per woofer (as I have), does it make sense to drive the VCs with UcDs wired in antiphase? Another question: is potential supply pumping reduced if the signal is high-pass filtered at 120 Hz? I ask because I can get my hands on parts for a 63 volt supply, which is about 20% below the 75 volt rating on the UcD400 output devices (although I might need to disable the OVP since it might kick in). Thanks in advance, Francois. |
#84 | |
Regards -- analog(spiceman) |
#85 | |
Is this what your talking about. http://www.lcaudio.dk/com/predpsu.gif |
#86 | ||
(Pumping does exist in full-bridge amps, but only momentarily when delivering power into strongly reactive loads) Quote:
I've never seen the pumping effect do anything noticeable on real music. You need quite specific test signals and test loads before anything dramatic happens. For realistic (unfiltered) music signals and normal speakers, normally sized caps (2x4700u for 8 ohm, 2x10000u for 4 ohm) is enough to keep your amplifier happy. |
#87 |
Thanks to Bruno and Jan-Peter for answering all questions so far. This is really excellent "pre-sales support" :-)
Another question: The UcD400 will give about 400W in 4 Ohm and 210W in 8 Ohm. How are they behaving into lower impedances? My speakers dip to 2.3 Ohm at about 55Hz. |
#88 |
Hanse,
Tis is no problem, when you ask to much current the protection starts to work. With normaly musicsignal this will not be a problem. The UcD400 has a piek current protection, when the current comes above 15A piek, the amps is shut down for 1-2 sec. Regards, Jan-Peter www.hypex.nl |
#89 |
Banned
Bruno, Jan Peter,
Great support you are giving here. In order to get a comparison of the two modules - Could you rate them sonically on a scale 1-100 (where 100 is the impossible nirvana). If you can give a rating for Highs,Mids & Lows - this would allow decisions to be made on the correct module for driving tweeters, woofers, subs etc in an active speaker setup. I don't believe I need the power of the 400 as I will be driving the classic BBC LS3/5A speakers (Nominal 15 ohm and no severe dips although low sensitivity 82dB). But if the 400 is sonically better than 180, I would use it anyway. John |
#90 | |
In practice, the 400W uses a different op amp and no coupling caps, which could give it an edge over the stock 180W. |
| UCD400 Amp | john65b | Swap Meet | 4 | 12th November 2007 11:08 PM |
| Page generated in 0.13329 seconds (78.01% PHP - 21.99% MySQL) with 11 queries |
