Go Back   Home > Forums > Amplifiers > Class D
Old 17th August 2005, 04:14 PM   #1251
IVX is offline IVX  Russian Federation
IVX's Avatar
Maybe i wrote the post in Russian too much, and noone can't understand it, but i'm sure that NTC+HeaterPTC for class D is really elegant three pin solution.
Best regards,
E1.
Old 17th August 2005, 06:22 PM   #1252
sx881663's Avatar
Default A question of starting
Hey guys,
How about something simple that will work? Use Chris's 20 ohm PTC but bypass it with a set of relay contacts. Have the relay driven from the rail voltage and set a resistance value in series with the coil so it don't close till say 80-90% of the rail voltage is present. This won’t require a heavy duty relay as when the contacts close most of the inrush is done. Seems this will solve the problem nicely.
Roger
Happiness is being owned by a cat
Old 17th August 2005, 07:35 PM   #1253
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
Yup that's the easy way, no point to using a thermistor though, simple power resistor would do.
Ivan I did have trouble understanding that I admit it.
Chris
Old 17th August 2005, 08:48 PM   #1254
I keep reading about bleeders - however, the modules, when "off", still draw a bit power from the caps.
My 22.000uF's are at very low voltage after about 2 minutes. Isn't this enough?
It's a moot point for me actually, as i'm changing to the Hypex PS, which seems to have lots of resistors parallel over the rails, must be bleeders
Old 17th August 2005, 11:53 PM   #1255
subwo1 is offline subwo1  United States
subwo1's Avatar
I think the idea of using the positive temp co thermistor to heat the negative temp co one is interesting. I guess both are wired in parallel. Just how well it would turn out functionally is something to observe.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 18th August 2005, 08:22 AM   #1256
IVX's Avatar
It is necessary to wait for cooling NTC, before next turning on. 3-10 min i guess.
File Type: png ntc.png (778 Bytes, 558 views)
Best regards,
E1.
Old 18th August 2005, 08:26 AM   #1257
Account Disabled
Now that I understand, t hank you!
Old 18th August 2005, 02:18 PM   #1258
I was talking about building my amp for pure stereo with volume control and a second line in straight to the amps for surround duties before...
In another thread I found this gem:
http://digitalanaloguediy.com/attenuator.html
Or this one:
http://www.hificollective.co.uk/comp...tiometers.html
Does this look like a nice solution for volume control? Also, what type is best for CD-player (cinch)->volume->UcD400AD? 10K type?
Is the quality identical?
Thanks,
Yves
Old 18th August 2005, 02:33 PM   #1259
wytco0 is offline wytco0  United Kingdom
Yves, not sure if thats a good idea or not as I am not qualified to say, however I am thinkning of doing something similar but using my S&B TX102 transformers as a volume control and housing them in the same box as the power amps.
What I dont know is if that would cause some sort of grounding hum type issues.
So far all the above exists as several boxes of parts !
Old 18th August 2005, 03:05 PM   #1260
Also see DACT and Goldpoint. Both do the same elma switches plus resistor things.
I have an 8 way DACT remote which is getting wired up in the next few days using an IR remote control gadget from Bent audio to help change volume without moving my fat **** for the couch...
Ed
UCD400 Amp john65b Swap Meet 4 12th November 2007 11:08 PM
Page generated in 0.13426 seconds (77.56% PHP - 22.44% MySQL) with 11 queries
