UcD400 Q & A
classd4sure said:
I've been pricing some power transformers, 40V rms secondaries at 650, 750 and 1000 VA. I think for two modules off one transformer I'd want at least 650VA.
So my question is this:
I've found "low noise" transformers offered, they don't even say what is different about them, such as any screens, magnetic shielding, or otherwise.
What is different is they're triple the cost of a regular one.
What's the consensus on having such a "low noise" transformer. Is it a must have? Is it a joke? Is it worth the extra cost? Would you notice any difference at all?
Now what I found was just marketing hype, no specifications offered or anything, so I'll also ask, how important is any screen /shielding as well, and we'll consider that to be low noise for the purpose of this part of the discussion.
I just ordered two 500VA transformers. I got a low flux density design, which results in less hum noise. As a result the transformer is a couple of millimeters bigger. I also got electrostatic shield and a magnetic shield. It also comes with the centre potted.
The only reason I got all the bells and whistles is because it didn't cost me much more. For a standard off the self it would of cost me around $120 (Australian), I paid $150.
The only reason I got the low noise design is a friend of mine tells me he can hear his transformer humming during quiet passages. You don't buy transformers every day.
Hello,
nickywicky;
Steel is a very BAD thermal conductor, please use a piece of aluminium. A size of 150 x 150 mm is already enough.
Peranders;
http://www.hypex.nl/classd/UcD400.pdf
DSP_Geek ;
The modulator PCB of the Ucd180 and UcD400 is EXACTLY the same:D
The higher the VA rating of the transformer, the better load regulation. So you will get the most power out of the UcD400.
Jan-Peter
www.hypex.nl
Jan-Peter said:
Hello,
DSP_Geek ;
www.hypex.nl
Sweet. I just got my UcD180s, by the way. Beautiful work.
So which part of the circuit is it which has the 1.8kohm input impedance? Is it easily modifyable to the 100kohm if the UcD400? At that point, one can use polypro caps for AC coupling and not have the capacitors dwarf the board.
Thanks,
Francois.
Calimero,
Outputpeakcurrent of the UcD400 15A.
A copy of a part of a documentation written by Bruno;
Given the fact that the frequency response is a second order filter cutting off at around 50kHz (the exact function is a sensible compromise between Butterworth and Thomson), the impulse response is accordingly. Frequency and impulse responses always go hand in hand. You may recognise the problem of trading frequency response with impulse response is a recurrent theme in audio converter design as well. A perfectly damped response corresponds with significant droop in the frequency response, and a maximally flat frequency response necessarily has some (though not in the case of a 2nd order filter) overshoot. Filter characteristics cutting the middle ground between Butterworth (maximally flat frequency response) and Thomson (constant delay) are mostly chosen.
Power response (slew rate) is limited only by the steepness of the impulse response of the output filter, which cuts off at 35kHz.
Keeping the discrepancy between power bandwidth and small signal bandwidth small is essential in preventing slew-rate induced distortion. During the course of the development of UcD, some had been made that were flat (>-1dB) up to over 100kHz, but they misbehaved quite terribly when confronted with wide-bandwidth input signals.
Francois,
The 1,8K inputimpedance is in the modulator, the small 90o potted PCB. When you like to use no coupling cap, you must use an other opamp as the NE5532, please go for an OPA2134. And you have to be VERY shure you source is DC free.
Succes!
Jan-Peter
www.hypex.nl
Just trying to come up with a bit of a plan here.
Luckily for me there's a good transformer manufacturer close enough to home to make buying from them a total none issue, as I'd imagine they can be costly to ship.
The primaries are rated for 115V rms, I need 120. I trust it isn't a big deal for such a primary to operate at 120.
I took that as a 4.3% error, to which I added another 14% to account for a standard mains variation of 10% safety margin, and the load regulation provided by them.
I also took into account a 1.4 volt drop to account for the bridge rectifier.
So I'm after 35 Vrms secondaries, am I not?
Just want to make sure I'm on the right track here.
Also, I'm having a hard time finding a place for PSU caps. I don't want to have to sell my ferrari to buy BG's so I was thinking of ELNA Cerafine caps, or another alternative.
If anyone knows of a good place to get them from at a good price, please let me know.
35 Vrms secondaries? Are u buying the UcD400's? If so you should have 40VAC secondaries. That is 40*1.41= 56VDC. That is, with a 10% variance will take it to 62VDC (which is below 63V limit).
I'm going to add some 47VAC taps (if I'm not too late) as well just in case it's required. Based on Bruno's and Lars discussion on another thread. May be able to run the UcD400 at higher voltage with some modes.
I have been lurking around this class D forum for a while, waiting for the time to pounce once the UCD400 was released.
I am planning on using one module to drive the bottom 2 open dipole woofers of the Linkwitz Orion, from 20hz to 120hz
This means the module would have to drive 4 ohms avg, lowest 2ohms at 100hz (two woofers paralleled)
In terms of power supply I was thinking 1*300VA, 40V secondaries per channel with one 6800uf cap per rail. Any comments or recommendations for changes?
Ta!:smash:
Ta!:smash:
If I were you, I would try the UcD modules also for mid and high. If you think UcD400 is overkill for mid and high, you could use the UcD180 for mid and high. I`m using UcD180 in an active dipole system, sounds great. UcD400 maybe better however since the coupling caps are gone, I`ll order some UcD400 modules later this year to try them out for mid and high as well. If those woofers are 4 Ohm each, you may want to spend one UcD module per woofer, you may not get maximum power at 2 Ohm because of output current limitations. And I guess those woofers need quite a bit of power, what do you use now to drive them?
Best regards
Gertjan
I got my ELNA cerafines (10.000uf) from partsconnexion
http://www.partsconnexion.com/catalog/CapacitorsElectrolytic.html
gertjan
Yep, UCD400s.
This is why I asked as I want to make sure I can get the most out of it, of course, but at same time I don't want it to go up in smoke. Of course, something seemingly so simple is not without its confusion either. For one thing you'll get different values for calculations starting from the secondary Vac ratings, than if you start with your end goal and calculate your way down. They're very close but there is a notable difference there, likely to be the percentage between the two.
More importantly, you didn't take into account a few other important factors.
Namely, load regulation of the transformer, and also in my unusual case, the difference of the given primary rating (rated at 115Vac, mains voltage here is 120). That's almost an extra 10%.
So we know that overvoltage protection kicks in around 63 volts DC right? I wasn't sure if it would be a good idea to aim for 63 volts worst case, so I was a wimp and used a conservative 60.
Let's be brave and use 62:) No.... 62.5
Mains voltage here is 120Vac, the transformer ratings are given at 115Volts primary 50/60Hz. I'm guessing it's likely manditory for this variation to be accounted for, as a 4% increase on the primary equals a 4% increase on the secondary ratings which they provide.
Another issue I'm not sure about is while mains here are supposed to be 120, each time I measure them I read it at 122. So let's use that, which is a 6% variation from the given primary Vac rating, and therefore on the secondary as well. Plus the 10% margin of safety factor, plus another 4% representing the transformer's load regulation rating.
So that's a total error of 20% to account for! That is, if I'm doing this right.
To the 62.5 volts end goal, I add a 1.4Vdc drop to account for the loss caused by the bridge rectifier, assuming there's no others.
I then have 63.9*(1-.2)=51.12Vdc
And Vac would be 51.12*sqrt(0.5)=36.1
Which tells me 35Vac secondaries (as rated for the 115Vac primary) are the right choice.
I have a choice between 35Vac, 38Vac and 40Vac secondaries.
For 35Vac:
35*SQRT(2)=49.5, now we add that 20% to bring us to worst possible case 49.5*(1+.2)=59.4Vdc - the bridge rectifier drop of 1.4V =58Vdc. Not exactly the 62.5..
For 38Vac
38 * sqrt(2) * 1.2 = 64.4881384
less the bridge rectifier: 63.1Vdc
Conclusion?
38Vac secondaries might be pushing my luck a bit?
35Vac secondaries might be too conservative?
40Vac is out of the question.
Opinions?
PS:
I also read that other post and it's making me wonder.. will that be the UCD700? Hopefully we'll get the info to make those mods. I don't think I want to have a custom transformer made but it's a good idea you had for the extra taps with that in mind.
Best regards
Gertjan
Thanks for your response, I am using a Pass Aleph 3 (30W) for the mids and highs and a Nakamichi PA7 (200W) for the bass, but the Nak is HUGE and I could do with freeing up some living space! I guess I could use one UCD180 per woofer, but that would work out slightly more expensive
Jan-Peter said:
Francois,
www.hypex.nl
So if I merely jumped the 22 uF caps the 5532 would have too much offset even if the inputs were AC coupled?
By the way, do you have a timeline for the UcD700?
Francois.
15 Amp max output current,
is that enough to drive a speaker with authority?
Don't misunderstand me, I find it quite remarkeble to have such spec for an amp of the size of the UcD400.
I was looking for an amp with at least the following specs:
- 300Wat RMS
- 60 Amps peak current
- 400 ns rise time, settling in 1,5 us -40db and a slew rate of 600V/us
That's what I have now and I would like to improve.
Henk
classd4sure said:
For 35Vac:
For 38Vac
Conclusion?
Opinions?
Well I can say that I went through all these kind of calcs when
deciding what transformer to get and also decided on one with
35Vac outputs too.
We are rated at 230vac here but it always sits at 240 so I needed
to take that into account like you have.
Also I wouldn't take off 1.4v for the bridge; that's 1.4V total so its
only 0.7 for each rail.
Need your advice, folks...
I am very interested in building an UCD400 based amp
with a decent power supply and high-end parts. However,
I need your advice now, folks. Since I'm a beginner in
amp building (I can solder well though and build a kit
from a few instructions), is this type of project really
doable for a guy without a degree in electrical engineering?
For instance, I don't know how to calculate VA ratings
of a torodial transformer etc. and I would need ready-to-use
modules (PSU etc.) that just need wiring. Would it be possible
to use modules from Schuro or LCAudio and just use them
with the UCD400s without having to be an expert? Or should
I rather buy a complete Zappulse kit instead? I am really
extremely tempted to buy UCDs but I don't want to end up
with a non-working project due to lack of knowledge.
Maybe someone who built the UCD with other "plug and play"
modules can comment on this?
Thanks for your help,
Michael
35Vac outputs too.
Thanks for chiming in there. I guess I was on the right path then, hopefully I'll see ~60Volts DC out of it. Anyway I look at the problem the answer always seems 35Vac.
Hmmm, interesting note about the drop for the bridge, we're both right. It's good you pointed that out though, I guess it depends how it's wired. I'm tempted to use two bridge rectifiers, one per secondary. I've heard good and bad things about doing that but it seems the general consensus is it's a better way of going about it.
Luckily should I change my mind it won't be enough to throw the results off by a large margin :)
The main thing is I dont' want to have to continually rely upon the modules overvoltage protection under normal operating conditions, but it will be there for the odd time the mains voltage spikes to >20% or maybe supply pumping pushes a rail a bit high.
Sound's ok. I think you may have doubled up on some of the percentages. The point of the initial 10% safety margin already includes the transformer regulation and voltage regulation at the mains (which is the main reason for the 10% margin). All you needed to do was take the difference between the mains rating and the primary rating.
Having said that, you got me thinking in regard to my selection. We have mains at 240VAC, I have requested 240VAC primary. Therefore, 40V*1.41*1.1=62V. Voltage drop of diodes may vary between different diodes and load so I didn't take this into account.
Hmmmm, should I go down a couple of volts?
Hmmm... I'm not sure about that. What if say you're working out the value for a puny little 100VA transformer for which the regulation factor is 10% on its own? Then you have no safety margin for the mains left?
This way I've accounted for both a 10% mains overvoltage which I understand is rather common place (if not more at times), and at idle condition (unloaded), worst case scenario, it still shouldn't be tripping the overvoltage protection circuit.
Oh, newsflash, and I quote Jan-Peter from a recent post in the ucd180 thread:
An unloaded voltage of 63VDC - 10% will be our advise
From this we see it does not include the transformer's regulation factor. So 63VDC+(whatever diode/rectifier drops will be in place)*(1-(10%safety margin + transformers regulation factor for the "unloaded" or "idle" condition+any other abnormalities such as I have in my case)).
By doing it this way we should be able to listen to it at a low volume (light load) while under the influence of a 10% mains overvoltage condition and not have the protection circuitry kick in, which I might add, doesn't just limit the voltage, but actually shuts the amp down for a few seconds. So it's important that we make a selection which won't regularly utilize the protection circuitry or it could be most annoying at every day listening levels.
It is good to second guess a few things at this stage of the game, I think, like you said a few posts ago it's not every day we buy transformers :)
So in my case now that it's on my mind again, if I want to play the odds of just how common a 10% mains overvoltage condition actually is, IF I use dual rectifiers (I per secondary) I might just be able to get away with using the 38Vac secondaries. Then again, how tight is the tolerance level for the overvoltage protection circuit, I could bite myself in the rump doing that. siiigh.
Should I play the odds here and go with the 38 or go with the safer more conservative 35's? Decisions decisions..
