UcD400 Q & A
UcD400 Q & A
Old 9th August 2009, 06:44 PM   #1731
egonnaud is offline egonnaud  France
I have no heat issue at all with 1 smps180 powering 2 ucd180 in a 40mm enclosure.
The output coil should be the hottest part.
Old 21st August 2009, 07:38 PM   #1732
Crafty is offline Crafty  United Kingdom
Thanks for the reassurance - hypex also confirmed its quite normal and safe for the voltage regulators to run hot with the smps. So looks like nothing to be concerened by.
Old 24th August 2009, 11:39 AM   #1733
teflon1 is offline teflon1  Denmark
Originally Posted by vincent s View Post
I test almost every hypex module,including oem version and hg ad version.
the test result is not so good.
I think they could make them better,but it seems that they do not think much of DIY market.
Have you a better amp to recommend then? Are there any on Ebay that you like? I don't know what to get anymore.
John
Old 27th August 2009, 07:39 AM   #1734
Virtalahde is offline Virtalahde  Finland
I'm going to stuff one UCD400HG and two UCD180HG's in one chassis for a monoblock. This is going to be used for a 3-way project.
What do you think, should I have separate 30-0-30 VAC (for the 180's) and 40-0-40VAC transformers (for the 400), or would a big, chunky 30-0-30v do fine with separate bridge rectifiers & caps for the 180's and the 400?
The capacitors used are going to be of good quality. Got a bunch of big 10,000uF Sikorels here..
Old 28th September 2009, 08:18 AM   #1735
muzzer is offline muzzer  United Kingdom
Default Another gain question for T
Originally Posted by Jan-Peter View Post
Resistor R3 (value 560), straight to the small side of the OPA2134/AD8620.
The gain is now 26dB, when you decrease R3 the gain will increase.
Jan-Peter
Old 28th September 2009, 08:31 AM   #1736
Question Another gain question for JP or Bruno
One for JP or Bruno I think.
I am using a Ucd400 with a SMPS400/67 installed as a "plate amp" in my Schroeder 1210 bass cab for live work. The sound is fantastic but I can't seem to get the output I would expect from this amp without causing my EBS MicroBass preamp to overload. I would like to increase the gain of my UcD400 slightly if possible to see if this solves my problem.
After trawling through the posts here, I found a reference to this:
Jan-Peter
I have had a look at my UcD400, but there is no OPA2134/AD8620 on the board - R3 is near a N5532 and seems to be 1.2k (marked 1201).
The board has UcD400v8 silk-screened on it and the sticker is marked 06091204-0095 so I would guess this is a newer version.
JP - can you tell me what I need to change to get the gain up to about 30?
Steve
Old 29th September 2009, 03:15 PM   #1737
NicMac is offline NicMac  Italy
NicMac's Avatar
UcD400 Q & A
Default dealing with reverse current flow
Hi guys,
On the Hypex FAQ (at http://www.diyclassd.com) I have seen an entry regarding "supply pumping" due to transient reverse current flows?!
For my UcD180HG HxR modules I am planning to test a regulated high current series supply. This supply type does not support reverse currents and I was wondering what type and size of the supply caps I need to deal with these reverse currents. I guess that also SMPS do not accept reverse currents - still they seem to work quite nicely with the Hypex modules.
Thank you,
Nic
Old 28th October 2009, 05:17 PM   #1738
AIS is offline AIS
Anyone compared the sound quality of the ucd400 powered by the SMPS400/67 compared to a standard transformer setup (for driving normal speakers, not subwoofers)? Is the difference noticeable?
Old 28th December 2009, 11:47 AM   #1739
totte is offline totte
I am planning to build Hypex UcD400 amps for a line source system and wonder:
To what extent will I benefit from using HG-modules with voltage regulators instead of ST-modules in the frequency ranges 15-100Hz and 100-500Hz?
How well will the UcD400 do with 3 or 4 8ohm woofers (6.5") in parallell? If I give them such a difficult load, should each have a separate PSU and will the SMPS do equally well as or better thatn the linear PSUs?
Old 5th January 2010, 09:12 PM   #1740
renpetra is offline renpetra
Hello I am starting soon on an dual mono project with the Ucd700 modules.
Everything to power my magnepans and I suspect a real good sound of of them.
Driving the maggies now with a rotel rb1080 amp.
I have order the first lot of mudules and a housing from hypex and mudus.
regards rene
UcD400 Q & AHide this!Advertise here!
UCD400 Amp john65b Swap Meet 4 12th November 2007 11:08 PM
