A new kind of Class D amp ? - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 6th September 2004, 09:22 PM   #1
Question A new kind of Class D amp ?
Hi all,
I have read a lot of threads here and I have a simple question regarding class D amps you can with out a doubt answer me
One of the more expensive parts in an amplifier is the transformer it adds a lot of weight and is expensive.
Has anyone done a class D amp with one 320V rail ?
Just the 230V and a rectifier, no trans.
I know it could simply kill anyone who is trying to connect the speakers while the amp is on, but this is DIY, I'm willing to bet a few bucks that you don't let people mess around with your equipment
The output stage would be a mosfet, and a small transformer, somewhat like the valve amplifiers use. (Why not do PWM at 1MHZ?)
The "front" side of the transformer would be from the +320V to ground through some high frq mosfet.
The "back" side of the trans would some feedback circuit and a lpf to the speaker.
Would this be at all doable or are the some major flaws in doing an amp like this ?
Best regards,
Gunnar I. T.
Old 6th September 2004, 09:31 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Hi Gunnar
You probably didn't notice but since yesterday we have a brand new Class D forum.
I'm sure you don't mind I moved your interesting thread over here.
/Hugo
Old 6th September 2004, 09:55 PM   #3
Hi Gunnar
I have done something like that, and it worked just fine!
I used IRF730N for MOSFET's for 200 Watts output power.
For transformer i used something from a tube amplifier.
All The Best from Denmark
Lars
Old 6th September 2004, 10:02 PM   #4
Hi Lars,
Do you have schematics for the amplifier you would be willing to share with the rest of us ?
Why do you think most class d amps use +- 70/50/30/24 rails ?
Is it easier to build? less hazardus (sp?) ? cheaper components ?
Is it hard to get the output trans ?
All the best from Iceland,
Gunnar.
Old 6th September 2004, 10:10 PM   #5
Gunnar: When you go above 200V (rail to rail) the MOSFET's tend
to get a much higher on-resistance, resulting in poorer efficiency of the
amplifier. Component price is more or less the same.
For audio i would probably rather have a slow and unlinear componnet as the transformer in the power supply, than in series with the output. That might be the reason you are looking for ..
Old 6th September 2004, 10:15 PM   #6
Lars, that is a very good reason
But would it be at all possible to build a class D amp without a transformer ?
Or would that just be silly, one would have to have a LP circuit in series with the speaker ?
Best regards,
Gunnar.
Old 6th September 2004, 10:24 PM   #7
Some would say you have a safety issue ..
But it as been done before in some commercially availble
subwoofers. I'm not sure they exist anymore
Old 6th September 2004, 10:33 PM   #8
LOL
Lars, thank you for good answers.
And if anyone comes across any links or schematics of transformerless Class D amps then please post it on this thread
Best regards,
Gunnar I. T.
Old 7th September 2004, 04:35 AM   #9
ghemink is offline ghemink  Netherlands
Originally posted by GunnarIT
LOL
Best regards,
Gunnar I. T.
Here you are:
http://www.flyingmole.co.jp/en/index.shtml
Everythin integrated on one circuit board and no transformer.
This stuff seems to be quite popular in Japan
Best regards
Gertjan
Old 7th September 2004, 06:27 AM   #10
Electrons are yellow and more is better!
peranders's Avatar
I think the main problem is to insulate the amp from the rest of your stereo equipment. A transformerless amp would never be approved in Europe and and in 230 V country. You have to make a switched mode power supply which can be quite light, not small though.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
How do I tell what kind of AMT I have? Urloony Planars & Exotics 0 1st February 2005 06:15 PM
What kind of cap is this ? Bernhard Parts 12 17th January 2004 09:07 PM
What kind of cap is this ? (2) rbroer Parts 5 11th February 2003 04:39 PM
What kind of cap is this ? (1) rbroer Parts 1 10th February 2003 07:24 PM
What kind of amp is this? swirv Solid State 5 1st February 2003 01:53 AM
Copyright ©1999-2017 diyAudio
