| Class D Switching Power Amplifiers and Power D/A conversion |
#941 |
A question for Jan-Peter,
Can I unsolder the blue led to place it in front of my box? |
#942 | |
#943 | |
I think I can help with this one. Yes you can, but note that the LED won't light up as it's been unsoldered.
#944 |
nice question
#945 |
Cable can help?? |
#946 |
hello all,
i have a couple of questions for the hypex designers. well, i saw the DS 1.2 subwoofer amp module on your site; it delivers 75 w mono. apart from the power issue, is that comparable to a UCD180 kit in terms of quality? on the other side, i would be very tempted to buy and built a UCD180 but then there is the problem of filtering the output and provide some quind of EQ or bassboost. are there any plans on your side to design a complete classD module with advanced bass management (maybe DSP, as the amp already works digitally)? thanx |
#947 | |
Kepa1, The DS1.2 is in a way an cheaper version of the UcD180. We don't have plans for a subwoofer with more options as the DS2.0 or the DS4.0. We are using our R&D time for more powerfull Ucd modules Regards, Jan-Peter |
#948 | |
I will replace the led on the UcD module with a 2 pins connector. I tested the mute circuit with the module. Works fine. I also replaced the original op amp with OPA2134. |
#949 |
Hi Folk!
I received my transformers and the amps are close to be finished. I've a stupid question again. Can we place (stick) a small heat dissipator on the ferrite inductor? |
#950 |
Won't you need an inrush current limiter for that big Tx and caps??
| Page generated in 0.12821 seconds (73.70% PHP - 26.30% MySQL) with 11 queries |
