Go Back   Home > Forums > Amplifiers > Class D
Old 14th November 2004, 03:55 PM   #931
Originally posted by Jan-Peter
You can put the /ON always on the GND line, but you can have some noises when you switch the amp off. Because the capacitors are discharging quit slow so you don't have a fast/sharp moment when the amps switch off. Please use the circuit in the attachment, every small NPN transistor will work. AC1 and AC2 are the secondairy voltages.
Jan-Peter
Your mute circuit.
No yet tested.
Old 14th November 2004, 03:59 PM   #932
The UcD180 mono block.
No yet finish...
Old 14th November 2004, 05:40 PM   #933
Stef1777,
Looks ok!
But why do you use the Schaffner netfilter?
In the most netfilters are mounted Y-capacitors (from live and neutral to ground) this can affected your sound because of earthcurrent. Bruno wrote in this topic that he never advise to use netfilters, becuase this degreed the sonic performance of your hifi setup.
Thereby with the UcD180 you don't need them for EMI suppression.
Jan-Peter
Old 14th November 2004, 05:43 PM   #934
Default IEC 230V AC connector
-stef1777
Hi!
Your picture shows a connector with filter. I'm sure I've read that it is NOT recommended. You should use one without the filter (X2 caps).
Other than that, it looks VERY nice.
BR
Roland
Money and power is no longer the solution to our problems. Money and power IS the problem.
Old 14th November 2004, 06:42 PM   #935
Hans L is offline Hans L  Netherlands
Hans L's Avatar
Stef1777,
Looks ok!
Jan-Peter
Can somebody elaborate on that? Is it advisable to not use that kind of filter on the amp or not even on other place in the house? Is it just the capacitor to earth or is it the whole ciruit? If you can't use these filters, how do you protect your devices against overvoltage (is a varistor also 'bad'?) or filter out the noise in the electricity?
Thanks!
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. --- Douglas Adams
Old 14th November 2004, 07:51 PM   #936
ingomar is offline ingomar  Germany
See my pictures in the UCD400 thread
Nice work.
ewildgoose, in the background of the picture appears something which I think looks like a mutlichannel potentiometer. If yes, how much was it?
Everything I could find was for outragus prices (US$ 300 and up )
-- Ingomar
Old 14th November 2004, 08:03 PM   #937
I already have iec netfilter on others equipements without problem. I'll try with and without if time.
Old 15th November 2004, 10:38 AM   #938
Indeed you are completly right, there is already a pull up resistor in the UcD180/400. So you can forget the +15V line by the transistor. A simple open collector output is already sufficient. There are all protection diodes inside the UcD180/400 so a higher voltage (max. 50VDC) is also no problem.
Jan-Peter
I tried the circuit alone (not connected to the UcD). I tried with an 2 x 25V transformer.
When the power goes on, the GND is well switched but I have 42 Ohms. I used an 2N2222 from my stock.
Is this normal?
Old 15th November 2004, 11:19 AM   #939
Stef,
Where do you have 42 ohm? From Collector to ground?
Seems quit highe but is ok when you like to pull down the /ON line.
Jan-Peter
Old 15th November 2004, 12:24 PM   #940
Stef,
Yes.
I can may be try to adjust the resistor to have a lower impedance. I'll try when I will have received my slime line toroid transformers.
Page generated in 0.13264 seconds (72.65% PHP - 27.35% MySQL) with 11 queries
