Go Back   Home > Forums > Amplifiers > Class D
Old 6th April 2010, 06:43 PM   #2421
Is there any problems to use a B1 Buffer to feed the Ucd180 modules? Even OEM versions? Any clues or hints for me?
cheers
Aykman
Old 6th April 2010, 07:09 PM   #2422
rtd is offline rtd  France
UCD input stage has a gain of 4.5.
Buffer works well (i tried some) but there's not enough gain.
It depends on your preamp and/or speaker efficiancy
Old 1st August 2011, 10:07 PM   #2423
orelli is offline orelli  Italy
Send a message via AIM to orelli Send a message via MSN to orelli Send a message via Yahoo to orelli
Hi Bruno, I just assemblate my UCD180 HG with regulators, but I've a problem. The amp works only at very low volume. I set my potentiometer at -50dB and the amp works, but at -40dB the the blue led turn off , and the amp is mute. Whit low level music I can hear at higher potentiometer position , but when the music goes up, the protection works.
I set the amp in this way( one channel):
trafo 2x30V
Ixys diode bridge
22000uF per rail
power supply voltage ,+/-42V DC.
Can you help me?
thanks in advance.
Best.
Old 9th August 2011, 10:23 AM   #2424
tfboy is offline tfboy  United Kingdom
I'm having problems getting some UCD180HG modules powering up.
The HXR regulators light up red, but the main blue LED stays off.
Can people confirm I have the power connected the right way up? The datasheets are confusing and have incorrect J pinout numbering so I want to be sure I have them the right way round.
BTW, I've also connected the yellow wire from SMPS400 to amp enable pin (pin 4 of Molex) but no joy. I've confirmed the wire shorts to ground after SMPS powers up and I've tried manually grounding pin 4 of the molex, but still no blue LED.
I've emailed Hypex support and speaking with them, but wanted to check with the community too
Here's a photo of my connections. red is positive, blue is negative, black is ground.
Old 9th August 2011, 11:59 AM   #2425
koldby is offline koldby  Denmark
Try to apply some signal or put a load on the speaker terminal. Sometimes the UCD modules does not start without.
What is Home Theatre without good sound?
Old 9th August 2011, 12:01 PM   #2426
I just found out the problem: the molex KK connector was wired round the wrong way!
I don't know if there is a standard for which end of the connector is pin 1, but I had a "1" marking on my connector and used that. I've only just realised that the illustration in the UcD documentation has pin 1 at the other end!
All looking blue now. Just rewiring the connector and will test in a moment
Old 9th August 2011, 08:54 PM   #2427
Hmm, amps now appear to be working but I have terrible ground loop buzz.
I want to have two inputs: one balanced XLR straight into UcD module, one unbalanced RCA going through a 50k pot to act as volume control.
I've attached a drawing of how it's wired up.
The buzz seems to come and go as I move wires around, or move my hand near the selector. It's really strange. I've double checked my wiring but cannot see anything obvious.
Any ideas?
Old 10th August 2011, 08:03 AM   #2428
As I see it :
In pos 2 the right channel red (now wired to 5) should go to 8 and 5 and 11 should be grounded.
If you use pos. 3 to mute the hole thing, 3, 6 ,9 and 12 should be grounded.
Old 10th August 2011, 03:09 PM   #2429
Whoops, yes, you're right.
Updated drawing attached.
I've started rewiring it all, and it's better, but I still have a problem, although think it's related to the pot...
Old 10th August 2011, 07:37 PM   #2430
Did you ground the potmeter?
That is the metal part of potmeter?
Page generated in 0.12810 seconds (74.49% PHP - 25.51% MySQL) with 11 queries
