| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Class D Switching Power Amplifiers and Power D/A conversion |
Thread Tools |
#2401 | |
Rg on the UCD 180 HG V-2 module is R14 (Rf=R12,R13). I think you need around 800R for gain of 10. Regards, Peter. |
#2402 |
Hi Peter.
In fact you are right. I've been in contact with Hypex today. I am thinking to use a gain of 4.5 (which is 13db). I wouldn't need the input stage from an amplification perspective. However, Hypex told me instead of passing the opamp by I should rather run a gain of 0 otherwise I'd get the impedance down to 1k8. Now I've got a couple of more questions: 1. To make the input stage gain 0 , can I just take out RG=R14=inf? 2. What do I have to consider in case of SE operation if IN- goes to ground and RG is open? THX |
#2403 |
Formula for calculating gain is Av=4.5x(1+2xRf/Rg).So to get 0 gain you would need to remove Rg or to put 0R link in place.
Hope that helps. Regards, Peter |
#2404 | |
I was just wondering if it can be that easy. I wanted to make sure that I don't mess anything up in SE operation.BTW. Do I really need a heatsink even if I just draw not more then a couple of Watts? |
#2405 |
Not a heatsink per se... A long time ago Hypex said mounting directly to a metalic chassis would suffice.
Troy Thinking positive doesn't make things better, it makes you a better person. |
#2406 | |
I haven't checked it, but I can't see why it would affect SE operation. You just decrease gain of the buffer stage. BTW Rg = 0, not inf. You just need to short it in place of original R14. Peter |
#2407 |
Koifarm,
You should never ever wire an input like that, unless you want to hear how good your cables don't sound. You're using them as a low pass filter, no doubt it sounds smooth, and truncated. You're also risking the infamous pin 1 problem. This really is not the way. I don't think it's PSRR you're risking, though the op amp stage likely boosts it quite a bit as it has some 120db PSRR plus the regulators. The modulator has 60dB PSRR flat across the audioband which is actually very decent. Remember it's not 80dB at 100Hz that plumets to 10dB by 10kHz. What you really ruin is CMRR, and you also bypass the anti aliasing /RF filters that every good input stage should have. Using your cable as a low pass filter is not a substitute for this. Really it's a terrible example as it has no regard to signal integrity whatsoever and blindly relies on the less is more theory which is just wrong. Regards, John |
#2408 |
Dear john,
i am not a man of figures but of experience. I use Hypex modules for more than 9 years( build more than 20 times ) without the opamp stage. And my experience is that there is less noise and i like the sound. Coupling the module like my way is no problem, i do not need 2 Capacitors in a row. My preamp has a big output Cap and the hypex has also a big input cap. So i have bypassed the hypex one. About driving 1k8 of impedance you just have to try if you preamp can do that( or check it first ). But having no noise in my tweeters ( 101 db ) with just leaving some parts is the best. Further i do not have to buy the expensive modules who are build with the better regulators to lower the noise, i can just buy the ST versions and tweak some capacitors. " less is more " is no theory, it is an experience. There are no theories who can describe how something sounds you just have to listen. I know this can be a shock for people how buy or build things just for the great spec's. But the best things i heard had not always the best specs. I say good specs is a good base but listen and make your own decision is the most important thing. By the way the opampless Hypex with and without tube buffer is used worldwide by privates and professionals in home and studio. And this is the best reference you can get. Ronny Last edited by Koifarm; 21st November 2009 at 10:45 AM. |
#2409 |
koifarm,
I prefer facts over fallacy and I do not let someone's experience or subjective perception stand in the way of them. As such I'd very much appreciate you refrain from stacking fibs and fallacies one upon the other to make your point. For example you haven't been using Hypex modules for "more than 9 years", they haven't even existed that long. Check the birthdate of this thread for quick evidence of that. Also building 20 or 20 million amps the exact same, wrong way, for your "friends", doesn't grant you more expertise than did the first one. If you're also to make a habit of such wild statements as privates and professionals using your method worldwide, to grant either it or yourself credibility, I will have to demand evidence of your polling, and the names to go with it. I'm telling you why there can be less "perceived" noise and audio to go with it, and you like tubes anyway, so after coupling them to an otherwise neutral and transparent amp you should like the sound. Guido Tent sells tube-ucd hybrid kits for these modules, and I'll bet you anything he doesn't wire them like you do. Oh, if only there was some way we could find that out. http://www.tentlabs.com/Products/DIY...2009_small.pdf Notice he doesn't compromise his modules as you've done? That's because he knows better. "Less is more" is simply an opinion and taken out of proper context it will usually be wrong as it especially is in this instance. You're not going to convince me you improved signal integrity or sound by circumventing the RF/anti alias filtering, or by cutting the legs off the common mode noise rejection ability of the module. Interfacing is a complete science and it's not up for subjective preferential debate. The module is designed in such a way that allows the very best methods that you'd be wise to make use of. Your point about how you can buy the cheapest edition and cheaply tweak it up to your preference level is interesting, but I think only from a profit margin perspective, not for achieving the best possible results. That you find no improvement with the superior module should be indicative of an issue with your methods, and it seems clear you lack the expertise to make the most of them. Furthermore it is likely you didn't find improvement with using your methods on the high grade modules because they've already far surpassed them. Bypassing the coupling caps alone, particularly on the standard versions where they seem to use electrolytic coupling caps versus the film caps of the higher quality version, explains your subjective improvement by itself. Interestingly enough you needn't shoot the legs off your modules in order to improve on the coupling means. Johnny |
#2410 |
Johnny, first of all you need to read better.
![]() I said i use Hypex modules not Hypex class D modules for more than 9 years. And second i never said i build a better UCD but i said i build a UCD i like the most. After using ST and HG modules for a view years i did not like them anymore. After modifying the UCD with tube buffers i discovered a new sound with i like much more. Once again it is all about the sound, you need to listen and then decide for yourself what you like. You do not need anybody to tell you what to buy/build. And sharing experience that is why we use this forum. ![]() These ones are the benefits: - You do not need HG version, just the ST version. Because i do not use the opamp stage i do not need the expensive HXR regulators.( it is much cheaper) - I have just one (de)coupling condensator in the audio path. - Because i need 4,5( instead of 1) Vrms to drive the UCD, cables pickup less noise. Just one fact hypex build the OEM versions of his ucd modules without the opamp stage attached. So that oem builders can use their own stages. ![]() On the pictures i use Hypex OEM modules these you can not buy as private person. Ronny Last edited by Koifarm; 22nd November 2009 at 11:40 AM. |
| Thread Tools | |
| Page generated in 0.15679193 seconds (79.53% PHP - 20.47% MySQL) with 11 queries |
