Go Back   Home > Forums > Amplifiers > Class D
Old 25th August 2004, 10:19 PM   #231
UrSv is offline UrSv  Sweden
UrSv's Avatar
Well, this one will set the standard in my living room:
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 25th August 2004, 10:25 PM   #232
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
hahaha! Give them time I say... give them time.
"We start at the beginning
Our goal for the new power amplifier series from PS Audio was to create a product that jumped the final hurdle – crossed the elusive barrier all amps in the past have been striving to achieve –(snicker) to sip from the Holy Grail of the elusive unified theory of power amplification."
Here's the page to read for a real good chuckle
http://www.psaudio.com/products/hca_overview.asp
According to them, they've "re-invented" the wheel!!!
Whew~ That's about all I can handle.
Chris
Old 25th August 2004, 10:26 PM   #233
UsRV: Neat!
Not that it's so critical for the 180W module (for the 400W it's more important), but I'm not seeing how the heat from the blue "T" gets conducted away to the box. If you bolt them to the box by the tapped holes in the T, you get the box to cool the amp.
Bruno
Old 25th August 2004, 10:26 PM   #234
Account Disabled
Nice! You really didn't fool around.
Old 25th August 2004, 10:39 PM   #235
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
how necessary are heatsinks with these modules ? I;m talking about normal, in-house use with normal sensitivity speakers. It;s pretty efficient so...
btw, seems i was right about that class a class d amp marketing bs stuff
Old 25th August 2004, 10:48 PM   #236
I run the 180w modules without additional heat sinking in open air. The Tee becomes like 60ºC.
The problem is when you lock them up in a closed box, the heat can't get out. Even a mere 3W of heat can build up to quite a temperature if you keep it in a box.
The story that "class D runs cool" is one that keeps bouncing back from marketing people. They grab the heat sink and complain hey this thing gets warm!
They don't realise that if you cash in on the efficiency advantage by reducing heat sinking, the heat sink temperature will go up again! Of course you'd feel the difference in heat output by holding your hand 10cm above the amp but that's beyond them.
Old 25th August 2004, 10:55 PM   #237
JohnW is offline JohnW  Hong Kong
JohnW's Avatar
“HCA-2 Hybrid Class-A Amplifier
The novel design combines a balanced JFET input stage with a digital class D switching digital output stage. The Analog stage was designed by PS Audio's Paul McGowan, the digital circuitry is the work of John Levreault of Orvelle Technologies."
Sounds like, Class A input stage - followed by analogue Class D Output stage - with FB after the filter (But maybe dual loop) fed back to Class A input stage....
Nothing new am afraid…. Just marketing BS
John
Edit :- 0.2% 1KHz 150W er ... "you know I would do this job at half the price" with this "performance" level you can forget about dual loop FB...
Life shouldn’t be take it too seriously, you will not come out alive anyway…
Old 25th August 2004, 11:00 PM   #238
UrSv's Avatar
Originally posted by Bruno Putzeys
UsRV: Neat!
Bruno
Thanks Bruno,
No worries. The T is bolted to a normal 5 mm thick L profile (20 * 50 mm) using Arctic Silver Compound between them (since it is well away from the FETs, which are insulated already as it seems, and no side effects should occur) and that L profile is bolted to the finned sides using the same compound. The shiny piece at the connector side of the PCBs is just a profile to get them same height using the 10 mm stand-offs. This means that the modules are only attached to the sides of the box and the whole sides may be removed easily. The assembly should be OK to transfer and dissipate the generated heat without too much effort or temp rise.
UrSv
Old 25th August 2004, 11:03 PM   #239
UrSv's Avatar
Fooling around. Why on earth would I do that? Did you doubt me?
UrSv
Old 25th August 2004, 11:11 PM   #240
Account Disabled
On a serious note, BS... oops. PSAUDIO has received an invitation to join our happy forums to further discuss their successful re-inventing of the wheel, with an audience who can appreciate the technical aspect of it.
Don't hold your breath, and I won't either.
Page generated in 0.13407 seconds (78.85% PHP - 21.15% MySQL) with 11 queries
