Go Back   Home > Forums > Amplifiers > Class D
Old 8th March 2006, 06:40 PM   #1881
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
I'd imagine that's 46Vdc under load, at 10% mains overvoltage unloaded it might trip protection. Have to try it and see. I have 31Vac secondaries and my rails are 47Vdc unloaded.
Old 8th March 2006, 06:48 PM   #1882
troystg is offline troystg  United States
troystg's Avatar
If it does trip it won't be by much. I can throw some bleeder resistors accross the caps to maintain a slight load.
But is 500VA enough for 2 channels?
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 8th March 2006, 06:50 PM   #1883
Account Disabled
It's what I'm using, stays nice and clean right up to clipping, haven't been able to warm up the transformer yet.
Old 8th March 2006, 07:00 PM   #1884
troystg's Avatar
Excellent. Thanks for the reply.
Troy
Old 9th March 2006, 12:39 AM   #1885
Javin5 is offline Javin5  Switzerland
Hello everybody, I'm new to this board and have a UcD180 question:
What is the power consumption of the UcD180 module with zero signal. with 1 Watt output and with 10 Watt output? Has anybody ever measured this? I know that the efficiency is really good at full load, but how about at these lower signal levels?
If I use no heatsink (i.e. just the blue heatspreader) in a breadboard setup, prior to building it into a case, can I safely operate the module at low output levels up to about 1 Watt?
I did a search on these questions and so far found nothing. Sorry if I missed something and these questions have been answerde before.
Old 9th March 2006, 01:40 AM   #1886
maxlorenz's Avatar
Hi Javin5:
Attach a metal plate to the blue T heatsink and crank it up
Good luck
M
Cheapest horn speakers: https://picasaweb.google.com/lh/phot...eat=directlink
Old 9th March 2006, 08:37 AM   #1887
I had the modules on for about a minute without a sink (yes, yes, I know, JP told me not to ) running very low levels (surely less than a watt) and things heated up so fast I turned it off very quickly.
Just grab some piece of alu, doesn't matter what it is and screw the UCD's to it - don't take the risk - don't forget that a few centigrades of temperature more have very negative effects on the lifetime of your electronics.
Old 9th March 2006, 11:07 AM   #1888
Account Disabled
Think you should be alright to do a quick test with the 180 (not 400) in this way, but it just takes a small piece of aluminum to be safe.
Old 9th March 2006, 07:39 PM   #1889
Thanks to everyone for your advice. As you suggest, I will attach a piece of aluminum during tryout, just to be on the safe side.
In my UcD180, the PCB is not flush with the blue T-heatspreader; it extends just a little bit, maybe 0.5 mm. Is this common? Can the PCB just be sanded off a little bit to allow a flush mount to the side panel of the case? Or is there a risk to damage something?
I could use a thin 0.5mm thick aluminum "in-between-plate", but this would create an additional thermal junction. What do you think?
Old 10th March 2006, 07:11 PM   #1890
mfb is offline mfb  United States
I went overboard and copied Kevin's design for my 5-channel amp.
Page generated in 0.10609 seconds (79.55% PHP - 20.45% MySQL) with 11 queries
