| Class D Switching Power Amplifiers and Power D/A conversion |
#1531 |
Hi Gertjan
Thanks, makes sense. Min ohms are not on the Hypex web site. I wonder what the official Hypex line is? Cheers |
#1532 | |
Bump |
#1533 |
There are no sonically difference between all versions of the UcD modules.
All modules doesn´t have a real minimum impedance. During test we always test the modules with a 1 ohm dummy load. The THD must be below 0.05%. You can save use the modules with a very low load, when the load is very low you have to check the temperature of the UcD amplifier. This will be the real limitation. Regards, Jan-Peter |
#1534 |
Thanks Jan-Peter!
#1535 | |
Jan-Peter |
#1536 | |
...and that would be ??? (except for the price tag) ![]() Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
#1537 | |
Account Disabled
![]() Anyway Jennice, the reason for the difference in cost for the upgraded version is obvious, go look up what an AD8620 would cost you from digikey as compared to an opa134. He's obviously not just stamping an upgraded mark so he can raise the price of the module. You're just getting what you're paying for. So your question now should be, what am I paying for in the AD8620 that I _don't_ get with an OPA134, and the answer of course lies within their respective data sheets, specifically, on the THD Vs Frequency curves, one is a little more in tune with the nature of the amplifier, so you can now decide if that's worth it to you. It would be for me. Regards, Chris |
#1538 |
Hi Chris,
Thanks for your explanation. That's the kind of thing I was fishing for ![]() Jennice
#1539 | |
This brings me to my question: If I should find need for it, can two UcD180 modules be used in bridge, provided that the heat sink is sufficient? Jennice
#1540 | |
What kind of crap answer was this: "There are no sonically difference between all versions of the UcD modules" How about addressing the questions I posted? What reason to change the modules, if it doesnt make them sound better? |
| Page generated in 0.12282 seconds (79.02% PHP - 20.98% MySQL) with 11 queries |
