| Class D Switching Power Amplifiers and Power D/A conversion |
#1401 | |
You're right and in fact my problem is here. What should I do when using a CC protection circuit (with common ground for the five channels)? Stephane In my drawing, speaker ground are not connected yet. |
#1402 |
Hi guys, nice to present worlds first automotive UcD.
![]() Powersupply by IVX ( http://amploid.narod.ru ) Caps: nippon chemi_con 17000uFx90V (4pcs) (OEM for ML) Currently running with ScanSpeak 8545K00 (10 ltrs sealed) + Eton ER-4 (ribbon) (first order both so far). Regards from Moscow.
#1403 |
Hi All,
May I know what's the (/ON) on the UCD180 input pin for? should I connect this /ON pin to power supply ground to un-mute the amplifier or should I leave it open for proper amplifier operation? Any kind advise would be great............ Thanks............ |
#1404 | |
Deep down inside. |
#1405 |
I'm having problem with the small circuit for silent turn off.I'm using the below circuit with few changes 1N4148 diode and 2N2222 bjt . In a board ,it is travelling to Hypex, I had intermitting signal output , then once turned off and then on it went completly silent with 9,7Vdc at the output and no signal . I completly semiconductors in the silent circuit seem to be ok and circuit cecked several times. What could be the problem? Giorgio |
#1406 | |
Ok this is the circuit Giorgio |
#1407 |
The circuit should work. I'm using it.
Check your ground connection. |
#1408 |
the circuit is in the same board with the diode rectifier, ground circuit is connected to central transformer wire and than to chassis.
Giorgio |
#1409 |
First to do.
Bypass the circuit and check the module with a direct mute's ground connexion. |
#1410 |
Done it, 8R power resistor as load and no signal at the output except 9,7Vdc regardless of the 33k resistor betwen -V and output I added to avoid the Vdc at the output with no load.
| Page generated in 0.13369 seconds (79.71% PHP - 20.29% MySQL) with 11 queries |
