| Class D Switching Power Amplifiers and Power D/A conversion |
#1041 |
classd4sure
I used to teach robotics... I work at a tech university and we have 13 robots or something, -so they have a tendency to end up on work shop pictures Yes... to protect the cabeling seems like a good idea, maybe I can cut and "line" the hole with a thin soft rubber hose... /Stefan
Electronic's - compressed smoke... |
#1042 | |
Other than that it's beautifully designed!
Michel |
#1043 |
I know...
-But each trafo is only 1*33V and I got them for free... Regards /Stefan
#1044 |
Disappointed, I thought cost was no object for audiophiles
Michel |
#1045 | |
Hence my setup? I'm not trying to be rude Stefan, just proud of my beast.
#1046 |
Account Disabled
Hi Stefan,
I forbid you to use hose! Everything else was done so meticulously, don't ruin that now. I was thinking of something like this http://mdmetric.com/elect/1/grommet1.htm http://www.cableorganizer.com/grommet/ You're probably thinking hose is quicker to put on huh ![]() Well if you really have to, maybe a piece of clear plastic fuel line wouldn't look that bad, with tie wraps to make sure it can't move. You'll hate yourself for doing it every time you look at it though. |
#1047 |
What do you think about this one...
http://www.elfa.se/elfa-bin/dyndok.pl?dok=6969.htm I have boxes of them at work... /Stefan
#1048 |
Account Disabled
It's better than hose but just as ugly
The way it sticks out you might have to cut yourself some longer wires too.. Didn't seem to be much slack in them.I don't think you'd have to order any gromets online though, should be able to pick some up fairly cheap locally? Home hardware kind of store, plumbing, ummm, any place that sells/installs automotive stereo and aftermarket equipment will surely have some. Seriously get some nice rubber gromets you don't want all that hard work to go to waste by putting even just one eyesore in there do you? There must be some gromets on those robots? lol |
#1049 |
Account Disabled
Hi Stefan,
Was just thinking, if you got rubber grommets you could very easily slice one side of them and squeeze them in around the wires, take you all of ten seconds to install them that way, if the diamater isnt' a perfect match you can even cut a little chunk out of it, use a dab of urethane bond or some other glue that works with rubber to seal them up where you cut it as an extra step, but that shouldn't even be required. Quick, easy, effective, and it won't take away at all from the beauty of the rest of your amps construction. |
#1050 |
I promise that I will mount these rubber grommets
-and supply picture evidence Thanks for the tip! /Stefan
| Page generated in 0.11498 seconds (72.42% PHP - 27.58% MySQL) with 11 queries |
