Class D troubleshooting
Old 16th July 2004, 07:56 PM   #1
bknauss is offline bknauss  United States
Send a message via AIM to bknauss
Default Class D troubleshooting
Hi all,
I've got a class D sub amp that has been having some troubles. The FETS on it seem to die somewhat spontaneously. I had it on originally, sounded great for a while, then just sorta died after a couple hours of use... not really hot or anything. I put in some FETs with a higher vdss, through on some pink noise, and within a couple hours the FETs gave out again. I've measured the rails, and they're pretty far under the vdss of the FETs, so I'm going to assume the power stage and the FETS are not the problem. I am going to assume there's an instability in the circuit... where should I start looking?
Thanks in advance.
Old 17th July 2004, 12:06 AM   #2
dmfraser is offline dmfraser  United States
Default SOP
Standard operating procedure when troubleshooting an amp. Run it with a 100W light bulb in seri4es with the AC power supply so you can troubleshoot it without blowing up the output devices.
Are the devices getting hot? If the switching time is too slow, they will get jot and die. Rise time should be a fraction of a microsecond. You do have a 25MHz or better scope? If not, a problem like this is really hard to track down.
Dan Fraser
Old 17th July 2004, 01:30 AM   #3
bob123 is offline bob123  United Kingdom
what you need is a hammer - big one though 20lb sledge hammer ought to do the job.
Old 17th July 2004, 02:49 AM   #4
anatech is offline anatech  Canada
anatech's Avatar
Actually, if the fets switch fast enough, the gates may get a coupled spike and short. Do you have zener diodes to protect the gates against spikes, especially reverse bias (off direction) ?
-Chris
Class D troubleshootingHide this!Advertise here!
Noise troubleshooting Class D Tom7227 Class D 10 4th December 2007 08:22 PM
Zen V8 Troubleshooting moe29 Pass Labs 13 20th March 2006 04:44 PM
JVC JA-S55 amp troubleshooting 80sJunior Solid State 0 20th January 2005 08:26 AM
help troubleshooting this diy pre-amp zobsky Tubes / Valves 21 3rd November 2003 12:06 AM
Troubleshooting MikeBike Solid State 3 30th September 2001 05:19 PM
