Class D amp Working
Class D amp Working
Old 5th July 2004, 05:57 PM   #1
sonu is offline sonu  India
Default Class D amp Working
Now I have my Class D Amp ready. And it is a wooopping 650W of real power to drive my 2 HUNGRY Little Subs @ 2Ohms Load. I have powered it at 70V driving P150N Mosfets, and the amp is quite cool even at high power levels. As I have used it for my subs, I have used a active Linkwitz crossover, and it has a real base.
I have'nt used any feedback but have made short circuit & Overload circuit which works perfect.
There is only one problem that i have there is a 150Kz sine wave of 3V PP showing on my oscilloscope on the output, with no input to the amp, is it due to the dead time between the pulses.
I have used a Filter inductor of 550uH with .68uf Caps, which is not a perfect calculation.
Can anybody guide me to get a spread sheet for filter Calculation.
Sonu.
Old 5th July 2004, 06:26 PM   #2
selfservice is offline selfservice  Italy
schematics please!!!!!!!!!!!!!!
Old 3rd August 2004, 11:23 PM   #3
sorinsistem is offline sorinsistem  Romania
Send a message via Yahoo to sorinsistem
PERFECT SOUND
Old 4th August 2004, 07:50 AM   #4
phase_accurate is offline phase_accurate
Isn't this simply the residual of the switching frequency ? In this case I wouldn't care about it for sub use unless you use very long cables (and you might therefore be a source of RFI).
Charles
Old 5th August 2004, 03:13 PM   #5
It was a problem with LC Filter, now it is solved,
I have also made 1500W RMS Amp to 2 Ohms Load working Perfectly OK, little heating in the Inductors.
Only thing i am concerned is still i have to perfectly design the LC Filter. I am not getting proper info on Butterworth Filter design.
Sonu.
Old 5th August 2004, 03:35 PM   #6
What do you mean by "perfectly" ?
Do you want to get rid of ALL the ripple ?
If so, I wouldn't recommend doing it ! While it was always recommended to suppress the carrier as much as possible in older texts, there is now a general agreement that you sacrifice less audio quality when using less steeper filters with higher cutoff frequencies.
Charles
Old 5th August 2004, 07:14 PM   #7
palesha is offline palesha  India
Congrates Sonu.
Changla vatla. Aaplya manasani ase kahi keleki khup changla vatatay. Mu punyacha aahe. He lok swatala khup shani samajtat. Software nanter electronics madhe aaplya lokani ase kahi keleki khup bare vaatle. Dhanyavad,
Mahendra Palesha
Old 13th August 2004, 05:10 PM   #8
Hi palesha,
mi pan punecha,
where do u stay in pune, any contact no. n what do you do, Sorry to reply late, I am not a regular user of net.
Sonu
Old 13th August 2004, 05:56 PM   #9
Dear Sonu,
I hv TV antenna booster factory in Pune. U can call me on 26355702. I am in Bhawani Peth, Pune. What about u?
Mahendra Palesha
Old 14th August 2004, 04:49 AM   #10
soundNERD is offline soundNERD  United States
sonu, we'd still like to see a schematic and pcb...
thanks
Class D amp WorkingHide this!Advertise here!
I got My class D working !! stocktrader200 Class D 16 31st July 2008 10:14 AM
20k watt amp a document or a working class H hienrich Solid State 15 2nd September 2006 04:45 AM
Class Q will be working next year! destroyer X Everything Else 14 1st January 2005 03:08 PM
Why do so few designs use opamps working in class A? fmak Solid State 19 23rd May 2002 04:25 AM
Copyright ©1999-2017 diyAudio
