| Class D Switching Power Amplifiers and Power D/A conversion |
#481 | |
USMPS http://groups.yahoo.com/group/switchmode/ |
#482 |
I think that IS actually what he HAD in mind.
If you for instance take an AND gate and feed one input with the signal to be "dead-timed" directly and the other one with its delayed version (through the use of some gates in series or an RC lowpass) you will have an output that will go from low to high with a delay and vice versa immediately. There are more refined versions possible that include flip-flops. Regards Charles |
#483 | |
Account Disabled
Hi Sub, Could imposing a delay not be done with less parts? Seems like alot of effort for a simple dead time. Neat idea though. All the same, do we really want to induce a fixed dead time, that will only help saturate the body diode.. leads to a very short mosfet life. I've been simulating what you proposed (three transistor driver), my observations: It serves no usefull purpose, and provides no benefit over the standard driver. These are complications I believe one would run into with a real implementation of it. In simulation it can be made to work half decent, almost as good as the standard two transistor driver, but not as good. The biggest problem with all these discrete drivers seems to be gate signal asymmetry, while you can control the low side driver easily enough, the high side driver seems to make the mosfet rocket on. |
#484 | |
40106+diode+RC delay,transistor OC output,emitter output voltage follower, DC(not AC)coupled N+P bridge -- This is USTC school robot team's first reliable MOSFET motor driver.
-- by yangyi,2002.(not me) Quote:
#485 | |
my three transistor driver/the standard two transistor driver? does "the standard two transistor driver" means voltage follower? in my three transistor driver, the first driver is at the low side,so it could also be called "two transistor driver". and, what does "do we really want to induce a fixed dead time, that will only help saturate the body diode.. leads to a very short mosfet life." mean? do you mean the dead time should not be fixed,but vary with the gate capicity? |
#486 | |
Thanks.
#487 | ||
Account Disabled
Why deadtime is bad: The more dead time you have, the longer inductor current freewheels through the body diode, saturating it. Once saturated it takes a long time for it to be able to recover and block voltage again, then you wind up turning the opposite mosfet on, and it rams current down the throat of a non recovered body diode=shoot through. You can help that by slowing the turn on, and having a fast turn off, but this isn't a cure, and the slower you turn the mosfet on, the hotter it will run! So it's really not a good cure. If you can eliminate deadtime, the body diode never conducts! That... is a cure. So yes, some form of adaptive delay, which, due to propogation delay of the logic circuitry required for that, still allows the body diode to conduct, but not for very long, would help. Predictive delay (http://focus.ti.com/lit/ds/symlink/ucc27222.pdf) is said to fully eliminate body diode conduction. So, THAT, sounds like a cure. Problem: IC's that use it like the one I just linked to are only for low voltage drivers, what the hell good is a 12V amp right. Also, the varying delay seen in either adaptive dead time or predictive deadtime, I think, is something a self oscillating design would naturally compensate for rather nicely. I've seen the patents and know how they do it, but it looks like a hell of a project for the DIY'r, got to be a simpler way to make a "delay locked loop". By the way, if this interests you, those are words to search for: "DLL or delay locked loop". Thoughts? |
#488 | |||
#489 | |
#490 |
classD4sure:
do you mean the circuit you posted before,with a diode across the PNP transistor's emitter? I don't quite catch it. could you explain it to me? Anyway,a pull up resistor plus a voltage follower plus the diode is simpler. why not use it? do you want to make a inverting drive at high side,so you need another one? when the input is already low and the output stays high due to the output coil, the diode turns on,prevent the base of two following transistor be pull under the output(the source of high side FET). |
| Page generated in 0.15416 seconds (81.33% PHP - 18.67% MySQL) with 11 queries |
